Results 1 to 10 of 10
    Veteran Member Three Rings denalist's Avatar
    Mar 27 2010
    2019 Range Rover Velar, 2020 Jeep Gladiator
    Modified OEM S6 airbox
    I have an extra S6 airbox for sale that I modified to get some extra turbo charger noise. Ready for shipping(on buyer) or pickup in CT. Thought someone on here might be interested in one already modded rather than doing it yourself.
    $75
    Established Member Two Rings Osifer's Avatar
    Dec 27 2015
    Fort%20Lauderdale%2C%20FL
    You should consider uploading a video to show the increase in turbo noises.
    Mar 27 2010
    Quote Originally Posted by Osifer View Post
    I would but I don’t have it installed anymore. I later went to roc euro but that was a little loud for my taste. Had to have some dealer work done (O ring recall) so I put the stock airbox back in and sold roc euro.
    I would say for anyone looking to do this....noise level wise, if stock is a 1 and roc euro is a 10, this is a 5. You can hear more whoosh from the turbo than stock for sure, but not at the roc euro level. Not sure if that helps but it’s kind of close in design, albeit homemade and cheaper, to the RS7 airbox.
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    Does it have the open port at bottom for secondary air hose, and was there any perceivable difference with increased hot air coming thru?
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Mar 27 2010
    Quote Originally Posted by 07S6 View Post
    No, that port is closed. It has two drain holes. I vaguely remember the airbox on my C7.5 A6 has it open but my S6 is closed.
    Veteran Member Three Rings MolonLabe300's Avatar
    Aug 16 2017
    Chattanooga
    I can vouch for this seller. Very easy to communicate with and has fast shipping.
    13 S6 APR ECU S1
    13 S6 SRM +4mm, Flex Fuel lines with ethanol sensor, Milltek turbo back, SRM Red Long intakes, NGK race plugs, AMG coolant pump. Merc HX, DS1 OTS stage 4, SRM TCU
    Mar 27 2010
    Quote Originally Posted by MolonLabe300 View Post
    13 S6 APR ECU S1
    Thanks buddy! Price drop to $75. Someone wants to give this a try ;)
    Dec 11 2017
    67 Chevelle, 997 C4S, Yamaha Warrior, Ducati SuperSport
    Ill try it, if you can ship to 18045...what filter did you use?
    Mar 27 2010
    Sale pending...
    Mar 27 2010
    SOLD!
