Results 1 to 16 of 16
    Veteran Member Four Rings AUDIFREAK23's Avatar
    Apr 03 2008
    NH
    S6 H&R ETS lowering module issues.
    ok, so like the title says, I have the HR lowering module. The issue Im having is I can get the module to adjust. Followed the very straight forward directions, kept the doors closed etc... No matter how many times I turn the front axle adjuster counter clockwise, the car wont raise. And I tried the 2 axle adjuster, nothing there either. Im not getting any kind of faults or anything, so im kind of at a lose.... PLEASE HELP
    Another note. the light on the actual module is constantly blinking. should it be solid? or blinking?
    2001 S4-->2004 A4 Ultrasport-->2007 A4 3.2L Sline-->2010 A5 3.2L Sline-->2014 S5-->2014 S6-->2016 SQ5-->2016 A7
    May 29 2015
    Calgary, Canada
    Quote Originally Posted by AUDIFREAK23 View Post
    Have you tried disconnecting it completely. Doing a full lower and raise then connecting it again?
    Where did you get the instructions? I'm looking for them as well as I'd like to know how to go about adjusting my height as well.
    '15 RS7 | Nardo Grey | Sport Exhaust | APR Stage 2 w/ DPs | Roc-Euro Intake | Cete ASC BT Module | Niche Misano 21x10.5 | Eurocode F/R Sways +Alu Kreuz | TAG reflectors | Neidfaktor Carbon Mirror caps | 10" Alpine Type-S Sub
    Apr 03 2008
    NH
    Quote Originally Posted by mavpsire View Post
    the car still raises and lowers from the button inside the cabin, so I dont think thats the issue. It almost like the brain isnt talking to the car. The directions I have came with the ETS. I know if you call HR they will send you the directions
    Apr 03 2008
    NH
    anyone?
    Apr 03 2008
    NH
    bump
    Jun 09 2017
    Signature
    GTA
    Have you tried lowering the car? The H&R module is meant for lowering and not raising unless you lowered it first with the module. Did you lower the car and now you can't get it to raise or you wanted to raise the car higher than the factory setting?
    Current Line-Up:
    2008 911 Turbo Cabriolet Manual
    2012 VW Golf R - APR in-house build Stage 4
    2002 Audi TT 225 Quattro Roadster - Big Turbo
    1995 Camaro Z28 6 Speed - Just Bolt-Ons
    Gone: 2015 Audi S6 - Stage 3 / 2015 Audi S4 - Stage 2 / 2012 Subaru Sti Hatch
    Apr 03 2008
    NH
    Quote Originally Posted by 15 Phantom S6 View Post
    when you plug the module in the first time, the car sits very low. So you need to raise the car up for dailey driving purposes. Im only looking to raise it enough for the edge of the fender to sit at the top of the tire, only about 3/4 of an inch from were it sits now
    Apr 03 2008
    NH
    bump
    Jun 09 2017
    Signature
    GTA
    Did you try the above??
    Current Line-Up:
    Apr 03 2008
    NH
    yes, twice
    Jun 09 2017
    Signature
    GTA
    I'll check mine out to see, but that might be your problem right there. I don't remember any blinking when I installed mine, but I also wasn't really paying attention to the light... You may have a faulty unit.. Did you buy it new?
    Current Line-Up:
    Apr 03 2008
    NH
    yup, brand new. So you have an ETS system. can you explain the exact process when you make adjustments with the module? there really isnt any exact directions for the process. Just want to make sure Im doing it correctly. I do it with the car running and all doors closed. The truck lid is open to access the module. When i turn the adjustment screws, nothing happens
    May 29 2015
    Calgary, Canada
    MY ETS system came with my car....and I've read as much as a I can about it without actually having an instruction set.
    From what I have gathered, after you make a change to the screws, you HAVE to raise/lower the car for it to be able to properly trick the onboard computer into the new height settings.
    Jun 09 2017
    Signature
    GTA
    I do the same process for adjustment.. What process did you use to install it? Is the car running? I installed mine with the car off, all doors closed and trunk open. I remember some folks disconnecting the battery too. Since the install is quick and easy, if you already install it with the car off, try to disconnect the battery, install and then re-connect the battery. IF that still doesn't work, you may have faulty unit.
    Is your unit always flashing 100% of the time or only when the car is on?
    Current Line-Up:
    Apr 03 2008
    NH
    I installed everything with the car off. In the instructions from H&R theres nothing saying to disco the battery....I hope that wasnt something that had to be done.... But im willing to try anything I guess. And no, the light seems to be flashing more then not. It almost flashes like its communicating with the car, like when a desktop is doing something and the light is flashing on the front, thats what it reminds me off. the other day when I went in to try the adjustments again, it was solid before I started to adjust
    I did yes. Ill try it again
    Apr 03 2008
    NH
    bump
