Results 1 to 18 of 18
Thread: Trailer hitch
    Established Member Two Rings modfan61's Avatar
    Feb 02 2017
    1988 Dakota 360Swap Project
    Connecticut
    Trailer hitch
    Hey all, been awhile since I've been on here but been doing some looking and can't find much. How many of you all have a trailer hitch on your A4 sedans? I need to carry my trail bike around somehow and the only hitch I can find mounts to the spare tire well. Just wondering how well that has held up for anyone that has that set up. I won't be trailering anything. Just would have a single bike rack mounted to it..
    2004 Audi A4 1.8t 6spd
    Feb 27 2011
    Winnipeg
    I'm looking into this for my B6 as well, I have the spare tire style hitch on my b5s4 however and it works great, I tow 2 jetskis on a double trailer about 160mile round trip every second weekend last summer and it held up great, I'm sure the curt hitch would be fine for a bike rack.
    There is one part number thats only listed for b7 avants thats no drilling required, it bolts to the exhaust hanger hole and the rear tow hook, if anyone can confirm if that fits a b6 sedan thats the way to go. The only reason I can't see them saying it fits is maybe because you'd have to trim the lower part of the bumper cover. The hitch I'm talking about is the curt 11180.
    Feb 02 2017
    Connecticut
    Hearing that, I think it will be okay too. Was just a little weary of having it mounted to sheet metal and all. I'd order the one for the B7 to find out if it fit, but I don't really feel like going through the trouble of returning it if it didn't fit
    Jan 21 2014
    GA
    How about a truck mount bike carrier like Thule?
    Nov 03 2011
    All Over!
    A hitch mounted to the spare wheel well, and not on proper structural parts of the car, are a bad idea.
    Yes, I’m aware a bike rack weighs very little, but in the unfortunate event you suffer a low-speed impact from another vehicle, the hitch will tear the floor out of the trunk. It would total your car. An impact on the hitch ball is very different to the impact on the rear of the car, which is often square, with a spread load.
    I would get the correct, load-bearing hitch for a B6 Sedan.
    1986 Type 85 Audi 90 quattro
    Nov 03 2011
    All Over!
    Quote Originally Posted by henri12 View Post
    This is a better option, than a spare wheel well-mounted hitch.
    Feb 27 2011
    Winnipeg
    They don't make any load bearing hitch like you guys get in Europe. Most if not all hitches that mount on unibody cars are drilled into the tire well and the Euro hitches don't have safety chain provisions.
    Senior Member Three Rings Dodaman's Avatar
    Mar 27 2018
    Quote Originally Posted by seanf86 View Post
    I just installed the curt hitch, Part #11164, from Etrailer. Everyone said it wouldn’t fit, but turns out Curt didn’t have a test cabriolet to try it out. Well, it fits great. Just a very small amount of the lower facia had to be cut. I am also using it to transport my 30lb mtn bike. As you stated, there isn’t a hitch available that will bolt to the structural part of the vehicle, so this is what we have from the USA makers. There is an option from an overseas company, can’t remember their name. I looked at it, but I didn’t want to shell out $500 total just to transport my mtn bike. This Curt one will be fine. I’ve bolted this rack onto many different hitches, and after this install, i’m not worried in the least about if it will carry the weight. Now, i haven’t loaded it up yet, so it may sag a little bit, but It will be minimal. Worst case, I may change racks to something smaller and lighter down the road.
    As for getting rear ended with it on, well, I can’t control that. I figure as much as it would suck, I have extra insurance for things like that, so I’m not going to loose sleep over and it. I’m going to enjoy the perks of being able to tote my bike to the trails. 😀.
    Good luck and enjoy.
    Aug 27 2013
    Philly
    Interesting that you use the s4 for towing 2 skis. I too have 2 skis which I tow with my dads f150. You must have some nicer boat ramps than around here because I usually have to have much of the rear axle of the truck in the water when I'm retrieving/dumping the skis. I also pondered 2 skis on the 3.0, but I would 100% have to upgrade the brakes. I think thats the my biggest issue aside from power....
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by SJorge3442 View Post
    They're older jetskis so they weigh under 500lbs each, I wouldn't dare tow some of the new pigs they make now, I've since split them up and got a single trailer and will only tow one from now on, usually I can get both skis in the water with just barely getting my back tires wet, maybe the exhaust starts burbling, they're all concrete ramps, I don't dare venture into the closer sand launch we have as I'm sure the low pro summer tires and wet sand wouldn't be a good combo.
    Sent from my Moto G (4) using Tapatalk
    Feb 02 2017
    Connecticut
    Fortunately, if I was rear ended, with my trail bike, my trail bike has more into than the car is worth and that would get destroyed and the person that hit me would have to cover that as well as the car..
    As for a trunk mount rack, the design of my trail bike really doesn't allow that kind of set up, with the way the top tube is on the frame. Plus, those trunk racks really aren't that secure IMO
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    second everything everybody said...the B7 trailer hitch one is of a better design. i personally have the Westfalia hitch...it bolts INTO the frame which is great...but to work with bikes, i'd have to buy a separate attachment. also the electrical wiring kit didn't work so i had to buy another.
    Feb 02 2017
    Connecticut
    Barry, I agree with them too. It is a much better design, but wasn't 100% on if it would fit my B6 and I'd like to be riding soon (this weekend)...
    Nov 02 2007
    SF Bay Area, CA
    you also could do roof rack with bike mounts. don't think that was mentioned.
    Feb 02 2017
    Connecticut
    Barry, thought of that too, I REALLY don't want to go that route of putting holes in my roof for a permanent installation. Sometimes I wish I had an Avant... this is one of those times
    Apr 07 2011
    The OEM roof rack does not require putting holes in the roof. The video shows a newer A4 but our roof rack mounts the same way.
    Senior Member Three Rings IndoReef's Avatar
    May 20 2015
    2018 VW GTI Autobahn
    Ontario/Canada
    My Thule roof rack is amazing, Carries my two jackson kayaks like a champ, just get a roof rack and bike attachment.
    Winter: 02 B6 1.8T quattro 01A Brilliant Black, Gutted Stock Cat, 2.5" stainless custom exhaust to 4 inch tips,DSMIC's
    USP Front lower Valance, REVO Stage 1, Solo Werks S1 Coilovers,B6 S4 Front Brakes, Forge Hybrid Diverter Valve, SAI & AC Delete
    Summer:2018 MK7.5 GTI AutoBahn
    Feb 02 2017
    Connecticut
    I already got the hitch and bike rack. I did get the Thule rack. Read so many better reviews on that than the Yakima rack
