My Audi A6 won't start. When I turn the key, the dash lights up, the MMI starts up, but when I turn the key, nothing. I've seen many post about this issue, but I haven't found many successful resolutions documented. (I will be documenting resolution, fyi.) Any help is appreciated!
Here's the scan:
Wednesday,18,April,2018,17:50:19:01374
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: WAUDH74F78N060872 License Plate:
Chassis Type: 4F (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 42 46 47 4F 52 53
55 56 61 62 65 72 77
VIN: WAUDH74F78N060872 Mileage: 196060km-121826miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (AUK) Labels:. 06E-910-559-BKH.clb
Part No SW: 4F2 910 559 H HW: 4F1 907 559 E
Component: 3.2l V6 FSI 0040
Revision: --H21--- Serial number:
Coding: 01050109190F0120
Shop #: WSC 08253 444 83875
VCID: 313C1C97BD290F6FCD6-8064
2 Faults Found:
012371 - Starter Control; Returned Message
P3053 - 006 - 50 Short to Ground
Freeze Frame:
Fault Status: 11000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 196061 km
Time Indication: 0
Date: 2018.04.18
Time: 15:30:31
Freeze Frame:
RPM: 0 /min
Mass Air / Rev.: 0.0 mg/str
Temperature: 84.0°C
Engine Off
Voltage: 12.34 V
Speed: 0.0 km/h
012424 - Starter Relay
P3088 - 006 - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 40
Mileage: 196061 km
Time Indication: 0
Date: 2018.04.18
Time: 15:30:31
Freeze Frame:
RPM: 0 /min
Temperature: 84.0°C
Engine Off
Voltage: 12.04 V
Speed: 0.0 km/h
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F5 910 156 HW: 09L 927 156 C
Component: AG6 09L 3.2 FSI USA 0010
Revision: --H04--- Serial number: 4376994
Coding: 0000002
Shop #: WSC 02325 758 00200
VCID: 6594B8C7B96193CFE1E-8030
No fault code found.
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AD HW: 4F0 614 517 AA
Component: ESP8 quattro H01 0070
Revision: 00000000 Serial number: 00000000000000
Coding: 0020895
VCID: 6696BFCB446798D7E84-8032
Address 05: Acc/Start Auth. Labels:. 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500898293
Coding: 0000003
Shop #: WSC 02323 758 00200
VCID: 6390A6DFB755EDFF0FA-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 C HW: 4E0 035 729
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 303IY077557466
Coding: 0000003
Shop #: WSC 02335 758 00200
VCID: 2310E6DFF7D5ADFF4FA-8076
Subsystem 1 - Part No: 4F0 910 609 E
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000881406
Subsystem 3 - Serial number: 0102.10.070000000100010508ÿ
Subsystem 4 - Serial number: 010508ÿ
Address 08: Auto HVAC Labels: 4F0-910-043.clb
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030291060
Coding: 0524326
VCID: 1C62DD23CAAB92078E0-8048
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Revision: 00000000 Serial number: 4F0907279
Coding: 0012123
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3485349
Shop #: WSC 00000 000 00000
VCID: 186AC1333E93FE27AA8-804C
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 K HW: 4E0 035 593 F
Component: SDAR SIRIUS H07 0140
Revision: 00000000 Serial number: AUZ4Z7G0169202
Coding: 0000100
VCID: 2F381AEFAB1D199FDB2-807A
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 40
Mileage: 196002 km
Time Indication: 0
Date: 2018.04.15
Time: 17:13:19
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 F HW: 4F0 959 655 A
Component: 6N AIRBAG AUDI8RH30 0300
Revision: 15H30000 Serial number: 00359D0G7KC%
Coding: 0013902
VCID: 2A0E0BFB90FF7CB70CC-807E
Subsystem 1 - Part No: 4F0 910 339 B
Component: BF-Gewichtsens. H03 0060
Subsystem 2 - Serial number: 6332CSME28236807/
Subsystem 3 - Serial number: 6342CSME28231053T
Subsystem 4 - Serial number: 6352QSME3C294459P
Subsystem 5 - Serial number: 6362QSME3C511F4BU
Subsystem 6 - Serial number: 63734SME3D12417F4
Subsystem 7 - Serial number: 63834SME380F531B5
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H03000 Serial number: 90055072630100
Coding: 0002041
VCID: 2708F2CF83ED41DF132-8072
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 C HW: 4F0 920 951 A
Component: KOMBIINSTR. M73 H16 0240
Revision: 00200000 Serial number: 64858GT97
Coding: 2065288
Shop #: WSC 40674 067 57207
VCID: 201AE9D3E6C3B6E7528-8074
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B079268404
Coding: E5D59E77301A0600
VCID: 2D0400E7A1116B8FE9E-8078
Address 36: Seat Mem. Drvr Labels: None
Part No SW: 4F0 910 760 HW: 4F0 959 760
Component: Sitzmemory FS H04 0050
Revision: 00000000 Serial number: 00000000896400
Coding: 0082946
VCID: 619CACD7AD49FFEF1D6-8034
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0210
Revision: 00000000 Serial number: V
Coding: 0035563
Shop #: WSC 02327 758 00200
VCID: 2C020DE39A0B6287FE0-8078
1 Fault Found:
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 5
Reset counter: 43
Mileage: 196002 km
Time Indication: 0
Date: 2018.04.15
Time: 17:13:08
Address 46: Central Conv. Labels:. 4F0-910-289.lbl
Part No SW: 4F0 910 289 J HW: 4F0 907 289 J
Component: Komfortgeraet H26 0210
Revision: 02100026 Serial number: 01068674880000
Coding: 4618269
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
1 Fault Found:
01506 - Bulb for Rear Fog; Right (L47)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 62
Mileage: 191413 km
Time Indication: 0
Date: 2007.05.16
Time: 12:02:01
Address 47: Sound System Labels: 4F0-910-223-BO.lbl
Part No SW: 4F0 910 223 J HW: 4F0 035 223 G
Component: DSP-High C6 H10 0240
Revision: PROD_01 Serial number: 00000000051573
Coding: 0000016
Shop #: WSC 02324 758 00200
VCID: 2514F8C7F9E153CF21E-8070
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 C
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000076127
Coding: 0002014
VCID: 5EE6972B9C37C017204-800A
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 792 E
Component: TSG BF H12 0210
Revision: 00000000 Serial number: CI
Coding: 0035563
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0005022
Shop #: WSC 02145 758 00200
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000003
VCID: 3FD84AAF7B7DE91F4B2-806A
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 394J4077817856
Coding: 0000002
VCID: 2E0607EBAC171097D04-807A
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: J0644 BEM H12 0590
Revision: 00000000 Serial number: 00000000147098
Shop #: WSC 00000 512 00290
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 0709271154
Coding: 344630393135313035442056413030373039323731313534
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0035370
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700056800
Coding: 0062221
VCID: 221EE3DBE8CFA4F744C-8076
1 Fault Found:
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 4
Reset counter: 61
Mileage: 195760 km
Time Indication: 0
Date: 2018.03.24
Time: 22:33:02
Freeze Frame:
(no units): 47.0
Temperature: 0.0°C
Error Code: 1
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0035370
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 E HW: 4E0 862 335
Component: Handyvorb2 H18 0950
Revision: 00000000 Serial number: 00000005009903
Coding: 0010900
End----(Elapsed Time: 02:01, VBatt start/end: 11.9V/11.8V. VIgn 11.7V)-----
