Picked up an 03 allroad with ECU immobilizer defeat. Was having a short through the cluster and the car only came with a valet key. I have tried to pair the new factory keys but VCDS just keep showing 0 keys. The cluster that came with the car had a short and was leaving several center console lights on leaving a drain. I copied the bin file from this cluster and then cloned it onto a replacement cluster. I think unfortunately there were codes for intermittent key and ECU communication that I saved and cloned. I am still getting the immobilizer flashing light on the replacement cluster as well as key and ECU codes from a VCDS scan.
Codes
Address 17: Instruments* * * * Labels: 4B0-920-xxx-17.lbl
* *Part No: 4B0 920 981 P
* *Component: KOMBI+WEGFAHRS. VDO D12**
* *Coding: 06264
* *Shop #: WSC 06117**
* *VCID: 336EB0BE01BB3ADCD5-50AC
* *WA1YD64B93N070068* * *AUZ7Z0B2278046
2 Faults Found:
01176 - Key*
* * * * * * 65-10 - Unauthorized - Intermittent
01177 - Engine Control Unit*
* * * * * * 49-00 - No Communications
In short is there a way to pair new keys to a new cluster to an ECU that has the immobilizer removed without getting codes and the flashing immobilizer light on the cluster?
I have VCDS and Vag Commander.
Sent from my VK810 4G using Tapatalk
