Results 1 to 14 of 14
    Established Member Two Rings crimson773's Avatar
    Aug 08 2014
    2021 EZGO RXV
    ATL
    Brake change question: do you also do rotors when you do pads?
    I'm due for a brake change, but the rotors seem to be okay, not worn too bad, not warped, no judder when I brake. Maybe I bought some cheap pads and they wore too quickly, who knows. Anyway, looking to do a brake job and save a little cash since tax season buried me. Do you all normally change rotors and pads at each brake change interval, or just the pads, and then the rotors as needed? I've always changed both when I did a brake job. Thoughts?
    Mar 28 2016
    I always do. If you are using the exact same pads you could probably get away with using the old rotors if they are in good condition.
    Nov 28 2015
    Montreal, QC
    i do too.
    S4 B8.5 no track, just enjoying spirited driving.
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Nope. Rotors should outlast pads.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Senior Member Two Rings EastTNPharmD's Avatar
    Jul 26 2013
    2002 F250 Crewcab short bed 4x4
    Knoxville, Tennessee
    On my b6 it was rotors about every other pad change. Never tracked the car and while some driving was “spirited” I’m a fairly boring person.
    2004 A4 UltraSport 6MT, KW coilovers, FT21, TT225, FMIC, Motoza tuned, 18x 9.5 AMG Replicas
    Veteran Member Three Rings Corradobrit's Avatar
    Oct 27 2007
    TX
    Quote Originally Posted by EastTNPharmD View Post
    You're giving us Pharmacists a bad name. We're not librarians.......LOL
    2014 S4 Premium Plus, Glacier White Metallic, Black Optics, DSG, sport diff, Nappa, B&O, AWE Touring/Res DP, GIAC ECU Stage 1, ECS CF rear diffuser, CR15
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    What thickness should the rotors be at minimum?
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Apr 16 2017
    Illinois
    Quote Originally Posted by Corradobrit View Post
    I'm a street pharmacist and I'm not boring. Does that count?
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    No, the rotors last a long time...
    Apr 04 2012
    MSP
    Yes - I always do. Rotors are cheap enough and you're already in there so why not?! Have you looked at the back side (inside) of the rotor? It's hard to see unless you get the car up and your head back there. Often lots of crud gets in there and it doesn't get cleaned out as well as the front side causing the inner side to get much more wear. I'm actually changing my rear pads and rotors tomorrow because the inner has worn down to metal almost - the outter looks fine!
    You can do pads only if you want if the rotors are not bad but you'll probably chew through the pads again very quickly.
    Don't buy OEM either - too many better and less expensive options out there.
    Established Member Two Rings esfyve's Avatar
    Feb 27 2018
    2013 S5 3.0T 2004 GLI 1.8T
    Connecticut
    Never heard of this, rotors always outlast the pads. If the rotors are good, no need to change.
    Established Member Two Rings mercedesinfarct's Avatar
    Jun 13 2017
    Philadelphia
    Doing stoptech rotors and pads this week
    Sent from my ONEPLUS A3000 using Audizine mobile app
    Senior Member Two Rings BigKeshy's Avatar
    Jun 01 2017
    West Orange, NJ
    The technical service manual from Audi dictates the following:
    Front Brake Discs (345x30mm) wear limit = 28mm
    Rear Brake Discs (330x22mm) wear limit = 20mm
    Take 3-5 measurements around the rotor to assess/account for any uneven wear (use a decent set of calipers for this, not a ruler). If your rotors appear to be in good shape, then there's no need to change to them.
    Regardless of your decision to swap them or not, you will need to properly bed in the new brake pads.
    2013 B8.5 S4 MT
    Mar 28 2016
    Quote Originally Posted by BigKeshy View Post
    And that's why I said if you're using the identical pads, you can probably get away with the current rotors. Bedding in is the transfer of pad material to the rotor (I am sure you knew that). When you switch pad material, you often don't get a good bed in and the brakes can chatter. That's what most people (incorrectly) refer to as warped discs. Discs don't warp, they chatter from uneven pad material transfer. That's why I always swap the rotors. They are that expensive, and it's such an easy job once you're already replacing pads.
