Originally Posted by
PeteJ
The area you are talking about is about 1/4" but you are over analyzing, the small gap is not going to cause a problem. This is a proven and tested upgrade that has been done overseas, now that the 8V RS3 is in North America it's our torn. The only difference is that I'm using the S6 rotor, not the RS7 rotor.
One another thing regarding rotor warping...that ship has sailed years ago; rotors hardly. if ever. warp. What most people think is a "warped rotor" is actually pulsation due to pad deposits from overheating and/or not using a suitable pad. Being that this rotor is larger it also has more thermal mass, that in addition to the improved airflow around the rotor will only help this upgrade survive under serious track abuse.
Call it overanalyzing, I wouldn't do it unless I could also get the appropriately-sized caliper and pad. That piston force is not optimally placed in the center of the rotor face any longer.
I'm well familiar with deposition and used to use hawk blues on the street for a couple of days after a track weekend to clean the deposition off of my rotors. Those rotors may be larger, but they're not any thicker and a true upgrade would have been a larger and thicker rotor with an appropriate fixed caliper which I guess doesn't exist.
For the record, I think the stock rears are horrible and my car squirms under heavy, high-speed braking as well. I'm not totally sold on this, but if it works for you, great and good luck with it.
