Have a 2001 a6 2.7t tip (stock except for k&n filter)and turbos don't seem to be working right,can't hear them spool up gauge only reads about 4psi at most (vacuum is about 28 at idle and seems to be pretty smooth,also I do not have a cel on
Searching for about a week since I noticed this ,seen in a search someone mentioned the brake light warning being on and no boost (but didn't have a solution)mine is on and thought it was the 2 little bulbs out of 10 in the 3rd brake light being burnt, changed those warnings still on LCD
Just overnigherd a rosstech cable until Tue can't scan
Went for inspection and they came up with 4 codes all related to a rear o2 sensor
P1114
P0138 (o2 sensor circuit high voltage Bank 1 sensor 2)
P1118
P0431 (warm up catalyst efficiency below threshold bank 2
Quick history,, bought car as a project with a flooded passenger side, TCM and harness was bad ( car was in Limp mode stuck in like 4th, ( but you could hear the turbos spool up
Haven't tried a boost leak test but might try to rig something up to do a smoke test to check for leaks until my real cable gets here , kinda doubting a leak seeing as a cel don't pop up
