Results 1 to 8 of 8
    Senior Member Three Rings Richieru456's Avatar
    Apr 30 2017
    New Haven, CT
    Please drain oil????
    So I went to check the oil level and seen this... anybody every see this? Is this ok? IMG_0246.jpg
    B8.5 gear shift retrofit | Led interior lights | Led license plate light | Led backup lights |Honey comb fog grille | Rs4 “quattro” grille | Afe dry filter | Ecs turbo inlet hose | Usp hfc | 245/40R18Y SUMITOMO HTRZ-III on Enkei EKM3 | Euro plate | Carbon fiber interior trim | Audi logo flog lights | Audi logo seat belt covers | “quattro” seat stopper |
    B8.5 gear shift retrofit | Led interior lights | Led license plate light | Led backup lights | Honey comb fog grille | Rs4 “quattro” grille | Afe dry filter | Ecs turbo inlet hose | Usp hfc w/ custom downpipe | SUMITOMO HTRZ-III on Enkei EKM3 | custom Euro plate | Carbon fiber interior trim | Audi logo flog lights | Audi logo seat belt covers | “quattro” seat stopper
    Senior Member Two Rings jdfelda's Avatar
    Nov 20 2016
    2010 Audi A4 Quattro
    Oklahoma
    Looks like you may need to drain some oil. Did you recently have it changed? It could be many things such as a bad sensor, too much oil, or it could even be that your car was parked on an incline when you checked it, causing the sensor to falsely read over filled. More information is needed, but I hope this helped.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    When I had my 2010 A4 I had the oil change done and it gave me a message like this. I think I just let it burn off the extra amount because the message eventually went away. But im thinking you need to drain some oil if you changed the oil. If this happened randomly I would be worried about coolant contamination.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
    Jun 30 2014
    West
    Edit
    MPG 24city 31hwy
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    This is exactly why every car should come with a dipstick. I'd order one immediately. Ecs has a couple different kinds available. Until you get one I'd pull the drain plug (or use an extractor if you have one) and drain about a quart of oil and see what the sensor tells you after.
    2011 A4 Avant Prestige S-Line
    Apr 30 2017
    New Haven, CT
    Quote Originally Posted by Novarider View Post
    I have one. Checked it. Some fine. Good level
    Jul 02 2017
    Knoxville TN
    Were you parked on a hill?
    Apr 30 2017
    New Haven, CT
    No
