Results 1 to 13 of 13
    Apr 21 2018
    Accrington lancashire uk
    Audi A4 2.0l fsi saloon
    Hi all. I acquired an audi a4 2.0l fsi on a 53 plate around 10 months ago with a top end rattle, which i diagnosed to the cam chain. so that got replaced as well as the cps and it's been fine since until the other day. Was coming home from work and whilst driving on the motorway the epc light came on and car lost all power, pulled over and it went out. stopped the engine and restarted no problems so carried on home and put it down to low fuel(called at the garage on way home and filled up). i scanned the car with a code reader and it showed P1020. so cleared the code and day after car ran fine. Yesterday went out shopping and on the way there ran fine on the motorway and when i came off and was in traffic epc light kept coming on then off, if i stopped at traffic lights it would idle fine but when i set off again epc light would come on for a few seconds and then would go out until i stopped again. parked up did shopping and set off back home. On way home ran fine again until i got near home and it started again, managed to get it home just, but now it wont start, it tries revs get to 3/400 but just dies straight away. scanned for codes and now its saying there are no codes. question is could it be the in tank pump that has packed in or am i looking at something more sinister.
    Many thanks
    steve
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Either the fuel pump or fuel pressure control valve. Clicky clickŪ
    Apr 21 2018
    Ok after giving the car a coat of looking at and testing a few things i've found that if i disconnect the fuel rail pressure sensor g247 the car will start and rev. will it be ok to run it like this till i can get a new sensor monday or will it damage something more serious.
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by stemac33 View Post
    If it seems to run OK just drive gently. Do you have any way (ex: Torque Pro) to monitor your fuel trims in real time?
    Apr 21 2018
    yes got torque pro , tested intank pump and seemed to be running ok. does the intank pump vary fuel delivery or is it a constant same pressure supply
    Dec 28 2006
    Western Maryland
    Tank pump should remain fairly constant. The high pressure pump varies the pressure according to demand.
    what is your LTFT running when steady state driving?
    Apr 21 2018
    Not sure yet just got up 4.30 am will check on way to work. Would this be a good replacement for the intank pump ebay item number 282912502905. Many thanks for your help
    Dec 28 2006
    Western Maryland
    That number in ebay gives me something totally different (not even car related).
    Apr 21 2018
    Hi sorry try this link:-https://www.ebay.co.uk/itm/KEMSO-340LPH-High-Performance-Fuel-Pump-for-Volkswagen-Audi-1-8-T-9-654-1025/282912592905?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2060353.m1438.l2649 . Ebay uk. Specifications:
    Flow: 340 Liter per Hour, at 43psi, 13.5V
    Operational Pressure: 43-90psi
    Pump Body Diameter: 5cm
    Dec 28 2006
    Western Maryland
    I think you would be better of purchasing an OEM or at least one made by an OEM supplier. The one linked will probably take a little modification to mount and will probably differ in output from the OEM pump which could cause some fueling problems. You can save a few $$ with this pump up front but may end up paying a higher price down the line getting it sorted.
    Apr 21 2018
    Have now replaced g247 fuel pressure sensor and cleaned the maf and the Christmas tree on the dash seems to have gone out for now. Will see how it runs on way to work this morning 15mile trip.
    Apr 21 2018
    Hi there after replacing the fuel rail sensor the car seems to be running ok. Monitoring the LTFT when driving steady it goes from 0.0% to 3.3 and as high as 5.7% but mostly between 0 and 3.3.
    Dec 28 2006
    Western Maryland
    Perfectly normal for a FSI engine. Sounds like you are in good shape!
