Results 1 to 29 of 29
Threaded View
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    C7/7.5 How to Launch
    For over a year now several of us have been in close correspondence with one another collaborating and experimenting the best launch techniques for the RS7 (Mickey has been using some of those same techniques for the S6 as well but modifying slightly because the DSG is much different than the ZF)
    I'll go in to some detail about what I do and Mick, Don and maybe Kevin can all chime in with what nuances they may add to their launch.
    1-We've found that despite conventional wisdom the best 60' happens with the car in dynamic vs comfort- I don't want to go in to great depth explaining why we've come to this conclusion and arguing technical points, suffice to say that collectively our group has over 200 passes and hold the Stage 1 and Stage 2 fastest stock turbo 60' and 1/4 mile times.
    2- a)there are two methods we've tried, both very successful, in loading the car to launch. The first we'll call the the hard launch- essentially you stand on the brake, hammer the throttle and bring the car up on boost and on the converter to about 2600-2800 rpm, release the brake and away you go. Positives: this method has given the very best 60' for me at stage 1 of 1.55 and Kevin at 1.51 on stage 2 (both on 104 fuel and file). Negatives: it breaks stuff, we've had 1 diff and 2 axles in our group alone using this technique- I will not be using it ever again because stage 2-104 is just too brutal and using that method is a ticking time bomb for your drive line.
    b) the second is similar to what the B8 guys call the "upswing approach". This method still requires standing on the brake hard - we’ve found any “creeping” or “lurching” will almost certainly prevent Amax shifting. Once on the brake push the throttle, not matting it, but enough to bring the RPM’s up and as the tach needle swings up you release the brake and stand on the gas, where you release is up to how good the surface is but usually I’m releasing the brake between 2200-2600 RPM’s. Positives: much easier on drive-line components as you’re not totally loading up the converter and boost levels at launch are not as high. Negatives: slightly lower 60’ but Don and I have found the difference isn’t dramatic- maybe .02-.03.
    3- Suspension setup- the above may not be completely new to some but I’m guessing the ride height we’re using is. If you’re serious about the track and have air suspension you need to get a Cete module. The module’s adjustability has been invaluable for experimenting with various ride heights and launch techniques. Through trial and error we’ve found that lowering the car helps 60’ and appears to lessen wheel hop and the damage that comes from it. Currently, Don and I are actually “raking” our cars meaning we’re lowering the front considerably more than the rear- I personally run at -30mm front / -13mm rear and I know Don does even more than that. This keeps the front tires in contact with the track better which we feel assists in forward bite vs having all the weight transfer to the back which is less optimal on street tires.
    4- Lastly, air pressures. Generally speaking, when temps are warmer we’re lowering air to 34-35 psi, which seems to work very well, when it’s cooler out keeping recommended pressures works best, 39-42. I will also mention it’s our opinion, based on our having little to no success when ambient temps are below 60-65 degrees, I can’t speak for a Stage 3 S6/7 but the torque output on a stage 2 RS on 104 is next to impossible to get hooked on cold pavement, no matter how good the prep.
    I'm sure Don, Mickey and hope the other regular track guys, especially those with S cars, will have some more input on what they do that works as well. Feel free to reply with questions or your input as we wanted to post this thread to help us all go faster more safely and with less damage to our beloved rigs.
    Carl
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
