Results 1 to 2 of 2
Thread: Maestro 7 help
    Junior Member Two Rings
    Aug 22 2017
    B6 A4 1.8T - GTRS, Q5 Brembo's, CTS front mount
    Edmonton, Alberta, Canada
    Maestro 7 help
    Hey guys I’m looking for some advice with maestro. First car is:
    2003 A4 1.8T Quattro
    IE rods
    Stock pistons, head
    ATP highflow manifold
    GTRS eliminator
    034 TIP
    SAI and EGR delete
    CTS turbo front mount
    2.5in test pipe and down pipe
    Bosch 550 injectors
    Stock MAF
    I’ve loaded the base stage 3 550 file on and it starts but idle is rough and it’s running super lean, maestro logger says 30-40 AFR. I’ve tried changing the injector constant using the injector wizard as well as modifying the battery voltage compensation as the maestro post on Audizine. Still no changes to idle and AFR. I’ve checked for any vacuum leaks in the system and it all checks out. Anybody have some tips or pointers on how to modify the tune to get it running better?
    Also, when I installed the motor I also put in a stage 3 SBC in with their single mass fhywheel. When I tried to move the car a bit, the grab point is super high, almost fully released the pedal before it starts to grab. Faulty clutch or possible install issue?
    Any tips or thoughts are appreciated!
    Aug 22 2017
    Bump any? Already went through the entire maestro thread on here
