Results 1 to 11 of 11
Thread: 3.0 o2 sensor
    Established Member Two Rings bmartin247's Avatar
    Nov 17 2015
    Denver, Co
    3.0 o2 sensor
    Does anyone know if the 3.0 front o2 sensors are interchangeable with any other model? I expect the 2.8 and maybe the 2.7t. My local junkyards don’t have any 3.0s
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    This is the b6 3.0
    Mfg 06C906265B
    This is the B5 2.8
    Mfg 078906265B
    Try it, just splice it in if the connector is different.
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Established Member Two Rings yanni6556's Avatar
    Jul 03 2016
    Sydney Australia
    Quote Originally Posted by bmartin247 View Post
    It’s a really crappy job to do the sensors. Why not just go aftermarket they would last longer?
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Quote Originally Posted by 19jdog View Post
    Based on another thread here about swapping O2 sensors, there's a resistor in the plug end that is "paired" to the sensor. If you splice it in without also using the plug, the sensor may not work right.
    Sent from my Pixel 2 XL
    Jul 28 2014
    SACRAMENTO
    I'm assuming that the op is getting a used one at a fraction of the cost of a new one. That being said why not take a chance with splicing?
    04 B6 A4 USP 2.7t
    Aug 12 2009
    Dirty Jerz
    If it's the primary O2, it could cause fueling issues as the car wouldn't have the right AFR if the sensor isn't reporting properly.
    Feb 27 2011
    Winnipeg
    first pic is a wideband, second is narrowband, no way can you cut and splice, get one from any wideband vw/audi 1.8t 2.0 vr6 3.0 if there is excess wire length just ziptie it up, most of the new ones cover a few part numbers anyway and the wires are for the longest application and come with zipties to tie up the excess anyways.
    edit there is also the 2.7t BEL code engine in the 03-05 a6 and allroad, I believe those are wideband as well.
    Nov 17 2015
    Denver, Co
    Quote Originally Posted by yanni6556 View Post
    Yeah it’s a pain but I’ve had a hairline crack in the passenger side exhaust manifold since I bought the car, so they only last about 8 months or so before they burn out. I pulled the last one out of a junkyard car and it lasted about a year before it gave.
    Nov 17 2015
    Denver, Co
    Quote Originally Posted by seanf86 View Post
    So do you think I can just spice any vw/audi wideband with my old connector? Most likely a 1.8 or 2.0 since they’re abundant around here
    Feb 27 2011
    Winnipeg
    Connectors are all the same, just make sure the wire length of the one you get is the same or longer than your original sensor.
    Sent from my Moto G (4) using Tapatalk
    Aug 27 2013
    Philly
    As someone who has experimented with "cheaper" oxygen sensors, do yourself a favor and just buy the bosch sensor. Its not worth the headache of changing it again in a couple thousand miles cause it fails early. I changed both front o2's last year (I know swear on changing in pairs) and went with NTK sensors to save a couple bucks. NGK makes these so I figured I'd be good, since Im a fan of NGK spark plugs. Well, 5k later and my drivers side failed. Thankfully it was the drivers side and not passenger (much easier to change) and I was able to swap it out in about 25 minutes.
    Moral of the story, go with a bosch sensor and be done and never worry again. Rockauto has them for $95. Just go that route. You'll thank me later.
