Results 1 to 7 of 7
    Established Member Two Rings Dr Awesome's Avatar
    Aug 21 2017
    Minneapolis
    Subframe Bolt Spinning
    Hello,
    I noticed one of my subframe bolts was missing the other day, so I ordered the OEM replacement (M12 X110mm Grade 10.9 torque to 81ft/lbs plus 1/4 turn).
    I went to install it and it wont tighten down, just keeps spinning
    Do you have to cut your way in to fit a wrench over the top nut, or can you get to it from above by removing the carpet in the driver side footwell? This is on my drivers side at the location indicated in the link
    https://imgur.com/a/cGvqW
    I have a JHM DTS for what it's worth
    Aug 24 2014
    Newport Beach, CA
    Is it possible to start by trying to helicoil the threads?
    2024 M3 Comp xDrive
    Veteran Member Four Rings ReggieNoble's Avatar
    Dec 17 2016
    B5 S4 Avant
    Fl
    I've heard supposedly that a proper helicoil is stronger than normal threads. But I'm something like that I would just tap it to the next size bigger bolt. My 2c
    Aug 04 2013
    Pennsylvania
    I think OP means the nut has come loose from the body so it just spins and can't be tightened. I've only ran into that once on a different car and had to an access window.
    To OP, are you sure the nut is spinning and it's not just stripped?
    Aug 21 2017
    Minneapolis
    You all raise some good points, how would I tell if it was stripped vs not connecting with the nut? The nut could also be loose and stripped? I don't know what the internals of this section look like. Is there a way to peek in from the floorboard rather than cutting in?
    Established Member Two Rings Daveb5s4's Avatar
    Jul 09 2016
    Coquitlam, Canada
    There is no nut. You will have to helicoil the hole. I pulled the sub-frame to do it. Have fun.
    Aug 21 2017
    Minneapolis
    That clears up all of my questions, thank you all for the fast input!
