Hey everyone. Want to see if you all can help me identify the issue at hand here.
Have a 07 RS4, 110k on the odometer.
Generally runs very well but I suddenly started getting misfire CELs (flashing and solid). Generally it’s for Cylinders 7 or 6.
It’s likely that the car is at a point where it might need a carbon clean and I am already assembling the tools and parts necessary for the job.
I’ve already replaced the plugs with OEM plugs. The plugs that were in there were also OEM and seem in pretty good shape.
Mod-wise it’s only a resonator delete. X pipe. And plugged vacuum lines for the exhaust valves. I’ve already checked to see if reattaching the lines to the valves remedies the problem but no.
Also, I should mention a few more things.
-The misfires always start >5700 rpms
-partially letting off the throttle seems to improve the issue
-it will randomly run perfectly and super strong.
-valve covers seem to be leaking a little oil. But it’s on both sides.
I have VAG-COM and I am also a fairly knowledgeable person when it comes to mechanics, etc.
Perhaps you could point out the best channels to log on VAG-COM to diagnose?
Sorry. A bit long. Any help is appreciated.
