Results 1 to 2 of 2
    Jun 25 2017
    nashua NH
    b8.5 2015 s4 dsg chatter at idle in park when cold ?
    so i have a 2015 s4 s tronic , and it seems when its cold out , on cold start i have a bit of a flywheel rattle , until it warms up , it goes away if i move into drive , and returns when its in park or n , when the car is warmed up a bit it goes away . i remember my 2011 evo and my cla 250 both had similar issues with the dsg trans in them . never really heard it on the s4 til now . the car just turned 50k miles and every thing else has been fine stage 2 for around 30k miles , i talked to my buddy at the dealer he said never heard of dsg issues ...lol
    2015 daytona grey S4 -nappa leather - alum optics - carbon atlas trim - APR stage 2 ecu and tcu tune apr charger pulley jhm 187mm crank pulley-apr cps - 034 trans and diff mounts - VMR 801 19x9.5 - luft carbon intake - ecs 2 piece rotors -macan calipers-red stuff-034 brace -h&r oe springs - bilstien sport shocks -cr-15-ledfogs-ecs rear carbon diffuser-ecs front carbon lip -rs4 steering wheel -rs4 shifter -jhm v2 test pipes- custom hfc downpipes with magnaflow x-pipe resonator -corsa exhaust
    Apr 08 2014
    I literally had this exact same thing, I could even force it to happen when warm if I lightly pressed the throttle and lifted, so in stationary and in Park at maybe 1,100rpm then lift. Would chatter..sounded like clutch chatter but knew it was impossible cause it’s a dsg and it’s not same concept as a light weight flywheel chatter issue.
    So I knew it wasn’t the dsg, I found my exhaust bellows weak and think dropped the internal sleeve. I cut them out and welded in a set of dual ply wire braided flex tubes..no more issue since. This issue was last year..
