Results 1 to 16 of 16
    Nov 14 2013
    earth
    Urs4 partouts///lots of parts///make offers...
    All prices are OBO & local pickup will make things cheaper.
    All sales sent through goods & services must add on %3.5
    and shipping is paid for by the buyer unless stated otherwise.
    Brand New parts:
    3. Leather ebrake boot--$50 shipped
    4. 034 check valve--$37 shipped
    7. Bosch fuel filter--$27 shipped
    8. Euro urs6 replica front bumper—$300 shipped
    9. NEW 95.5 urs6 sport steering wheel badges—$105 shipped
    USED parts:
    1. Near mint urs4 black interior minus
    the front seats--- $700 + shipping Have
    a set of front seats I can include now.
    Willing to entertain offers for the black interior
    SWAP!!!!
    4. urs4 dot headlights with broken tabs--
    $100 picked up or $150 shipped within CONUS
    They have good glass, projectors, & wiring
    5. Mint urs4 orange factory side markers--$125 shipped
    Mediocre orange set-- $65 shipped
    6. Mint urS red outer tail lights-- $125
    Mediocre outers— $65 shipped
    10. Good AAN belt tensioner--$57 shipped
    11. Inner tail lights with cracks-- offers?
    12. Good doors-- $150 + shipping a piece
    or $600 shipped for all 4 within conus
    13. Good trunk with all the badging and license plate bracket--$250 + shipping
    14. Good hood--$100 + shipping or $100 picked up
    15. Good rear bumper with brackets, all 3 upper trims, and bumper shocks-- $250 +
    23. Working AAN stock injectors-- $107 shipped FIRM
    26. Inner & lower timing belt covers--$100 shipped
    All clips intact!!
    28. Airbox audi logo cover with a crack in it-- $57 shipped
    30. Both mint strut mount covers-- $57 shipped
    31. good condition urs4 grill with decent badge—
    $100 + shipping
    32. AAN block with a spun bearing--$500
    Shipped obo— Rebuildable..
    33. urs4 a/c HVAC box— $100 + shipping
    34. Non leaking power steering hose—$100 shipped
    Only have the shorter one..
    35. Good ZF steering rack--$150 shipped
    37. Metal end tank intercooler & crossover pipe-- $220 shipped
    38. Nice factory boost hose set--All 3---$100 shipped
    Throttle body hose, turbo outlet hose, michelin man hose
    I have 2 pair
    40. AAN oil pan --$140 shipped
    41. AAN valve cover--$75 shipped
    I have 2
    42. AAN water manifold- $75 shipped
    I have 1 includes the sensors on it
    & coolant banjo bolt
    43. Steel power steering bracket--$57 shipped
    44. Steel alternator/AC bracket with idler pulley--$75 shipped
    46. Good A/C components except compressor-- offers??
    47. A/C pressure lines- $125 shipped
    49. AAN fuel rail-- $107 shipped x2
    50. AAN Bosch fuel filter with bracket & hardware---$40 shipped
    51. urS good condition airbox with a brand new Mann air filter and air ducting--
    $150 shipped —no broken tabs or clips—Both intake ducts
    52. AAN maf--$100 shipped 1 left
    screens removed
    53. Nice AAN turbo inlet hose--$107
    Each will include a good 710a diverter valve.
    55. urs4 early 5 speed 01E trans-- $300 + freight shipped within CONUS.
    Has fresh dealership gear oil. I have one left
    56. urs4 early locking rear diff--$150 + shipping within CONUS
    57. urS4 nice axle set-- $300 shipped within CONUS.
    Factory GKN set in great shape. No torn boots or rust.
    Will include all hardware as well. I have 2 sets
    58.Good urs4 driveshaft-- $100 + shipping
    Working cv's & center bearing
    59. G60 front uprights-- $300 shipped
    I have one set left
    62. Front 26mm sway bar-- $50 + shipping
    Rust free...
    63. Front subframe-- $100 + shipping
    Rust free!!!!
    64. Rear subframe--$100 + shipping
    Rust free!!!
    65. Rear diff crossmember--$50 + shipping
    Rust free!!!
    66. Urs4 instrument cluster with bad LCD screen
    and odometer gears broken-- $50 + shipping
    Urs4 instrument cluster with good working lcd screen,
    dash lights, but odometer gears unsure of. $250 shipped
    67. Very nice set of Fuchs wheels with all 4 center caps
    intact will include all 20 lug bolts--$500 shipped obo
    Set of beat up urS Fuchs all 4 no center caps—$250 shipped
    68. Rear uprights-- $250 shipped —Rust free
    69. urs4 rear wheel hubs--$125 shipped
    Rust free
    70. rear control arms---$100 + shipping
    Rust free
    71. Full size urs4 mirrors--$250 shipped
    Working motors...
    73. window motor set all 4--$125 shipped
    3 sets—All work....
    74. Windows- $100 + shipping a piece or
    $200 + shipping for all 4
    75. Stock turbo oil & water line set-- $125 shipped.
    77. Strut bar--$50 + shipping
    78. Every switch, fuse, relay, module, etc
    from a 93 urs4---$125 shipped
    79. urs4 rain trays-- $100 + shipping
    82. Switch panel above the radio with all
    the switches--$100 shipped
    83. Stock clutch pedal-- $57 shipped
    84. Stock brake pedal-- $57 shipped
    85. Stock throttle cable--$57 shipped
    86. urS 5 speed 01E shifter linkage set -- $200 shipped
    Includes lockout box, both linkages, shifter, and the crossrod
    87. Mint trunk interior trim-- $100 + shipping
    88. Mint brake dust shield set--$150 shipped
    All 4 — Rust free
    91. Stock shift knob needs recovering-$25 shipped
    B5 s4 shifter $35 shipped
    93. Non rusty urS gas tank will include the pump
    assembly and cover-- $250 picked up or $450 shipped
    95. Good brake master cylinder-- $107 shipped
    96. Good power steering reservoir--$57 shipped
    97. Good windshield washer reservoir with good pumps---$80 shipped
    98. Good AAN longblock with all accessories
    Cyl 2 had 125psi & cyl 4 had 137 psi
    Reading went up after oil was injected into the cylinder. Could use rings or use as is.
    $1,250 + freight will include intake manifold, replica rs2 manifold, k24 turbo, turbo lines, dipstick tube, oil pan, oil pump, oil cooler & lines, good cylinder head, timing components, coolant flange, thermostat housing, valve cover, flywheel,
    coilpack cover, throttle body, fuel rail, injectors, fpr, motor mount brackets, sensors, the whole nin
    99. AAN block with a spun bearing--
    $500 shipped or $400 picked up
    Lots of other parts available
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    2012 TTS Roadster, 1995.5 S6 Avant
    Kansas City
    PM sent
    Previous vehicles: 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Jun 15 2018
    Charlotte
    I was wondering if you still had the euro front bumper for sale. I sent you a PM.
    Nov 14 2013
    earth
    Bump everything is obo. I need to clear room in storage. I pm’d you back.
    Nov 14 2013
    earth
    All prices are OBO & local pickup will make things cheaper. Everything is obo—make offers as I need to clear storage
    space.
    All sales sent through goods & services must add on %3.5 and shipping is paid for by the buyer unless stated otherwise.
    Brand New parts:
    10. Goetze piston ring set — $75 shipped
    USED parts:
    Used parts:
    1. urs4 black interior swap
    $700 + freight
    All clips intact!!
    $100 + shipping
    I have 2 pair
    I have 2
    screens removed
    I have one set left
    Rust free...
    Rust free!!!!
    Rust free!!!
    Rust free!!!
    Rust free
    Rust free
    Working motors...
    3 sets—All work....
    All 4 — Rust free
    Senior Member Three Rings Pizdets-b5's Avatar
    Dec 21 2013
    Portland/ME
    How much for the hood shipped to 04042
    Do you have a radiator support too?
    Nov 14 2013
    earth
    I’d have to get you a quote on the hood.
    I do have radiator support set too.
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Nov 14 2013
    earth
    Bump
    Bump
    Nov 14 2013
    earth
    Bump
