Results 1 to 11 of 11
    Mar 12 2017
    N.C. USA
    What I found out today
    Stopped @ my local dealer re some routine service & asked the SA wh to change the fuel filter as I could not find the answer in my manual. SURPRISE. There isn't any! How long has this been going on or is this just an AUDI thing? Anyone ever had a fuel problem because of not having filter?
    2020 Q5 prem plus Matador red/Beige
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    There is a fuel filter. It's located in the tank by the low-pressure fuel pump assembly. PN for your B8.5 is 8K0201511TA
    DIY here:
    https://www.audizine.com/forum/showt...1#post11674139
    and a video:
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Senior Member Two Rings shellraider's Avatar
    Dec 03 2015
    North Dakota
    Quote Originally Posted by LINDW4LL View Post
    DIY here:
    What a mess of stuff in there!
    2012 Monsoon B8 A4 Avant S-Line Prestige Package Black Optic : KO4, OEM Gauge Conversion, OEM Facelift LED Brake lights, OEM RS Interior Door handles, Full Engine Rebuild IE, Solid pipe, ECS intercooler, Porsche brake kit
    Veteran Member Four Rings Crucible35's Avatar
    Apr 22 2010
    13 Lawnmower Prem. Quattro
    Markham, Ontario. Canada
    Guess you shouldn't do it with a full tank of gas! lol
    '15 A4 S Line Q Tip Monsoon
    '09 A4 Premium Q Tip Meteor (Gone)
    Senior Member Three Rings alhutch's Avatar
    Jun 03 2017
    Portland, OR
    Quote Originally Posted by w123houston View Post
    interesting, the service manual for my allroad says there is one under the car.
    Those instructions are for a car equipped with a diesel (1st instruction of Step 2 says to fill new filter with diesel).
    2013 Allroad - Volcano Red
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    this is somehting im not planning on touching until it gives me problems
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Quote Originally Posted by JeriQo View Post
    Yeh don't, its not designed to be serviced like a normal fuel filter is, and the guy doing it in the video is retarded for dumping gas everywhere. That car is going to stink of gas for WEEKS.
    Apr 20 2018
    Houston, TX
    Quote Originally Posted by alhutch View Post
    you are correct! apologies for the confusion. post will be deleted
    May 22 2013
    Southern ME
    Quote Originally Posted by Crucible35 View Post
    No, run it down as far as you can first. I changed mine at 100k, not a huge job just make sure to buy a replacement ring, you'll probably break yours taking it off.
    Mar 12 2017
    N.C. USA
    Thx for all the replies. Ck w/my local indy guy. Fuel filter & fuel pump are both in the tank. He recommended replacing the tank that comes with both the filter & pump. I would guess that the VW saves $$ this way.
    Veteran Member Four Rings audrobotic's Avatar
    Jun 30 2014
    West
    Quote Originally Posted by greasykid View Post
    This fuel filter is the kinda thing you only do preventatively when youre bored or have 200k miles. If this was a 90s Honda it would take about 5 minutes. Since it looks like you have a 2014 I say this is way overkill.
    Current: 2013 A4 TFSI | Past: 2010 A4
    CAEB Longitudinal EA888 Gen2 155kW
    MPG 24city 31hwy
