Results 1 to 6 of 6
    Active Member Two Rings cha2ga's Avatar
    Mar 03 2013
    SC
    RNSE code retrieval
    I have a 2006 A4 B6 Cabriolet for seven years. I would like to replace the RNSE because mine is bad. I have found several but they do not have any codes with them. They do provide the donor car VIN. I have a genuine RossTech HexCan cable and VCDS. My question is, can I replace my RNSE with one that only has the VIN provided and can I do it myself with my existing cable? Is there a guide for the VCDS portion anywhere?
    Thank you.
    Veteran Member Four Rings xalents23's Avatar
    Oct 26 2011
    CA
    Only way to get the radio code is from the dealership.
    Jul 25 2016
    1995 Land Rover Discovery
    Missouri
    Skip the dealership. Every time I've gone through a dealership for a radio code, they've tried to charge me an hour of labor to look it up. If you call the Audi Customer Service line, they'll look it up and give it to you for free.
    May 09 2012
    Virginia
    Quote Originally Posted by SkiahMutt View Post
    This. You will need the VIN from your car and the AUZ number from the radio. You can either call or do it via chat on the Audi site. It's free.
    Mar 03 2013
    SC
    Quote Originally Posted by jbain2 View Post
    How do you get the AUZ?
    May 09 2012
    Virginia
    Quote Originally Posted by cha2ga View Post
    Turn on the radio. It will be at the bottom. Code that starts with AUZ...
    Sent from my VK810 4G using Tapatalk
