Results 1 to 27 of 27
    Veteran Member Three Rings dlo93's Avatar
    Jun 27 2012
    1998 Audi a4 1.8t, 2012 Volkswagen GTI
    Bridgewater, New Jersey
    Whats going on with this trans shifts???
    Can this be normal DSG symptoms or is there a problem here?
    Car details
    15k miles
    034Motorsport tune ECU/TCU
    187mm/57.5mm
    93Oct
    https://www.youtube.com/watch?v=3QIZ8ttuzzI
    2014 phantom black s4//20% tints//Carbon imports low kick spoiler//APR Stage 2+ dual pulley ECU and TCU//APR CPS//Roc-Euro Intake//AWE touring with non-res downpipes//
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    Are you talking about the "lag" or "slip" in the beginning of the video? Mine does the same, been so since 39k miles.
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
    Jun 27 2012
    The brief slip/lag in between shifts
    Mar 05 2015
    Orange County, CA
    Quote Originally Posted by dlo93 View Post
    I've had the same issue on my Stage 2 tune, don't know if it's because of the power making it slip but a lot, and I mean A LOT of S4 videos I watch upon WOT have the same issue.
    []SQ5
    Jun 27 2012
    Quote Originally Posted by USAF_Danny View Post
    Yea ive noticed the same thing also. The weird thing is my car is stock with 36k miles and it happens. I hate it. Im worried it will get worse when i go stage 2 this summer.
    Mar 05 2015
    Orange County, CA
    It actually doesn't get worse, and I've noticed that it only happens on WOT.
    Mine did it when it was stock too and that was 20k miles ago. You'll be okay at stage 2, promise.
    []SQ5
    Jun 27 2012
    Why the hell does it happen. A 63 thousand dollar cars dual clutch should shift with perfection. Biggest complaint with this car.
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    Mine sometimes shifts and it feels like hitting a brick wall. I'm not 100% sure if it's all TCU. It often feels like car is cutting out fuel/power completely. Other times it feels like the clutches are slipping and it doesn't engage right away.
    Sent from my MI MIX using Tapatalk
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Same here , it’s annoying . Thinking about switching TCU . Share this video
    https://youtu.be/zbN3-K4CiaE . It’s done it in every tune file . Met a guy at the track having the same issues .
    Jun 27 2012
    Quote Originally Posted by Rodizzle View Post
    Yea im thinking about going with APRs ECU and TCU. Hoping the tune helps. I cant stand it.
    Dec 19 2010
    North CA
    Are you guys on 034 as well?
    Jun 17 2015
    Bayarea
    Quote Originally Posted by miztahsparklez View Post
    I am
    Jun 27 2012
    Anyone have some more input?
    Jun 25 2017
    nashua NH
    my apr trans tune does not do that , im stage 2 + with apr tcu tune
    2015 daytona grey S4 -nappa leather - alum optics - carbon atlas trim - APR stage 2 ecu and tcu tune apr charger pulley jhm 187mm crank pulley-apr cps - 034 trans and diff mounts - VMR 801 19x9.5 - luft carbon intake - ecs 2 piece rotors -macan calipers-red stuff-034 brace -h&r oe springs - bilstien sport shocks -cr-15-ledfogs-ecs rear carbon diffuser-ecs front carbon lip -rs4 steering wheel -rs4 shifter -jhm v2 test pipes- custom hfc downpipes with magnaflow x-pipe resonator -corsa exhaust
    Jun 27 2012
    Quote Originally Posted by daytonas4 View Post
    Hopefully the TCU tune will clean it up. Maybe the clutch plates need more pressure.
    Jun 25 2017
    nashua NH
    yep i think that is it , i know from a recent apr training session that the apr stage 2 tune is set to give less power if the tcu is not tuned with it . most likely for that reason
    Jun 27 2012
    Gotcha, its just odd because im experiencing this and my car is stock.
    Dec 19 2010
    North CA
    Stock means your mech unit or gear selector sensors are on it's way out. Lol
    Jun 27 2012
    Will any of that show up through a VCDS scan?
    Dec 19 2010
    North CA
    No. You will just find out later when you are stuck on the road... Lol
    Jun 27 2012
    well damn
    Established Member Two Rings badazzstang's Avatar
    May 10 2017
    13 S4, 90 Mustang GT Convertible, 94 LS400, 07 F150 Supercrew, 2010 GX460
    Waco, Tx
    I read a thread with ARP a while back that they were having issues with this on stage 2 and TCU tunes. They said the fix was that they shift pressure needed to be adjusted/fixed in the TCU tune. The increased torque and insufficient clutch plate pressure caused a slight slip. If my memory serves correctly. They claimed it would not cause any issues and they eventually got it fixed.
    2013 Glacier White Metallic S4 DSG/Black Nappa - EPL Stage 2
    Jun 27 2012
    Quote Originally Posted by badazzstang View Post
    Gotcha, thanks for the info. I was actually just reading more about that exactly.
    Jun 27 2012
    11
    Jun 17 2015
    Bayarea
    I’m so tempted to drop my 034 tcu to go with apr
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    If you notice that road needed help, and you might be dealing with traction issues just a thought.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jun 27 2012
    Quote Originally Posted by TexasDfwS4 View Post
    Im noticing it with a stock s4. No way is traction an issue but true its something to think about.
