Results 1 to 17 of 17
    Feb 17 2018
    California
    Shortcut to switch into DYNAMIC mode? (Not the asterisk button)
    Most likely someone figured this out and I might be late to the game however...I hate cycling through the dash or asterisk clicks.
    While driving in COMFORT and stopped at a light (D and Comfort displayed on dash), I grabbed the shifter, pulled in the trigger button on the shifter and pulled back once on the shifter. This "appears" to be placing the car into DYNAMIC mode, changing "D" to "S" but not changing the display showing "COMFORT". I didn't touch the asterisk button, the Drive Setting dash button or throw the shifter right..into M.
    I say "appears to" because, idle rpms go up, exhaust louder and throttle response are noticeably "dynamic". Tried this same procedure again while in motion and I could hear the car revert back to COMFORT idle and exhaust sounds with the dash still showing COMFORT.
    I'm gonna test this again tonight on my drive home but thought I'd ask if anyone else noticed this or if I'm just plain crazy.
    This is a post PORT HOLD car.
    Dec 14 2009
    Houston, TX
    Try launch control, that’s the ultimate test.
    Nov 06 2017
    Vancouver
    What you are doing is putting the engine and transmission into sport/dynamic mode. The steering, dampers and quattro system will all still be in comfort however.
    Veteran Member Three Rings javbomb's Avatar
    May 11 2013
    Sydney
    Yeah... Known fact. Even an A3 will do this.
    C7.5 S6 | Black | Stage II IE ECU/TCU
    Veteran Member Three Rings FuzzyHat's Avatar
    May 21 2010
    Chicago, Illinois
    Quote Originally Posted by Skunkwerx View Post
    Mostly like someone figured this out and might be late to the game however...I hate cycling through the dash or asterisk clicks.
    I have a post PORT HOLD car as well. I literally drive in Dynamic mode, and pop it into "S" whenever I drive it. If you want the loud exhaust after starting up and in park, then you have to cycle through again to get the valves open. I just pop it into "S" don't know if that does the same thing, but seems to open it up, just haven't tested it out fully. If not, I will GLADLY cycle through and do that, as its just worth it. I only drive in Comfort mode if the little one is asleep in the back and we are on a long car ride.
    2018 RS3 - Unitronic ECU - Unitronic TCU
    May 11 2013
    Sydney
    Quote Originally Posted by FuzzyHat View Post
    Pulling the stick into S mode works the same as cycling back to dynamic again.
    So my car is always in dynamic, when I get in to drive I just pull back to S and it's in full dynamic mode for that drive. Quickest way to do it.
    May 21 2010
    Chicago, Illinois
    Quote Originally Posted by javbomb View Post
    Perfect, that’s what I was hoping. But in park and you want to rev, you still need to cycle sadly. Damn computers lol
    May 11 2013
    Sydney
    Only if that is the first thing you do when you get in the car. Which if it's cold is not a good idea.
    May 21 2010
    Chicago, Illinois
    I 1000% agree
    Feb 17 2018
    California
    Quote Originally Posted by Potatohead_RS3 View Post
    Thanks for clarifying this for me.
    Senior Member Two Rings seanix9's Avatar
    May 24 2017
    Melbourne - Australia
    ^^ Spot on.
    Cycling through will give U the 'true' dynamic mode.
    2016 RS3 SB. 2015 A4. 2018 RS3 Sedan
    Current: 2018 Ara Blue RS3 Sedan
    Past: 2016 Glacier White RS3 SB
    Instagram: Melbourne_rs3
    Sep 01 2012
    Edmonton
    Maybe i missed something but what does this have to do with a car that was held at port? So are you looking for exhaust sound or all settings changed to dynamic?
    2018 RS3 Panther Black
    Veteran Member Four Rings a4000's Avatar
    Nov 30 2004
    Pittsburgh
    The only problem I have with the explanation that putting the car into S puts the car into dynamic is if that were true, why even have the transmissions settings at all if it is actually controlled by D/S.
    Also, what you're saying is you can never be in Dynamic D or Comfort S, which is false.
    '17 Audi S8 plus // DS1 // E40 // SRM TCU // SRM Flex // SRM Manifolds // SRM 3" Intakes // 034 HPFP // ARM Downpipes // Milltek Non-Res // Ibis // Black with Arras Red Stitching // Dynamic Package // Bang & Olufsen // Black Optics // Driver Assistance // Cold Weather // CETE ASC // 21x9 Ferrada FR8 // PS4S
    '19 Q7 3.0T Prestige // Audi Design Selection Murillo Brown // Luxury // B&O // Black Optics // Adaptive Chassis // Cold Weather // Tow // Night Vision
    Feb 17 2018
    California
    Quote Originally Posted by WAF View Post
    Only pointed out after PORT HOLD because its still unknown truly why the cars were held (emissions, ecu flash, mud flaps etc) for the duration. Most of us were told ECU flash therefore its unknown what if anything might be different between 2017 model year (MY) builds and latter 2017 for 2018 MY builds delivered before the hold.
    Veteran Member Three Rings thebc's Avatar
    Jun 02 2013
    Boston, MA
    Not to worry, this is very common DSG logic for pretty much any VW or Audi DSG transmission. Go experiment with individual mode and you will get an idea as to the granularity of drive select. All you are really changing is the transmission.
    '18 RS 3 - Gretchen build thread
    '16 Golf R /sold
    '10 S4 /sold
    Nov 06 2017
    Vancouver
    Minor niggle, but does anyone else wish there were two individual modes? I mean theoretically they could make fifty of them for minimal cost, but you know, that wouldn't leave room on future models for more.
    Sep 01 2012
    Edmonton
    Oh, yah i haven't heard of an ECU update/tsb confirmed. So your car is a 2017 correct? Seems like to get true dynamic you have to cycle thru DS like others have mentioned from my experience.
