Results 1 to 26 of 26
    Veteran Member Four Rings S-Fore's Avatar
    Sep 17 2007
    SQ5 Part Out / Take 1
    What a Sale!!!
    Only mirror caps left!
    Aluminum Mirror Caps, for vehicles with factory Lane Assist. They are covered with Xpel Stealth for long lasting protection of the Matte Aluminum Paint (as they do not make actual aluminum mirror caps any longer). Absolutely no broken tabs and gives the Q/SQ that classic ‘S’ model look.
    (Fit Q5/SQ5/Q7) $185
    Senior Member Two Rings DizkoDan's Avatar
    Jun 08 2011
    2017 Dogde Durango R/T
    Ashburn, VA
    Well priced stuff. GLWS! I missed what you are moving into?
    *current* 2014 Ibis White q5 3.0t
    *sold* 2013 Ibis White s-line a3 quattro
    *sold* 2004 cobalt blue allroad 2.7t
    Veteran Member Three Rings jnabeel's Avatar
    Jun 22 2011
    Specialized Sirrus X
    Milwaukee, WI
    I need the rear license plate mounting. There is like a rectangle plastic piece actual plates mount onto. I don't have picture but can get one. Basically the whole mounting piece for rear plates.
    Please let me know if you have. Mine is only two screws work in, and is leaking, when wet, this yellow residue down back of my SQ5.
    Please let me know. PM me please.
    2018 SQ5 Premium Plus, Ibis White, S Sport Package
    2019 SQ5 Daytona Gray, Prestige, S Sport Package
    2015 SQ5 Glacier White with Black Optics Package (Sold)
    2008 RS4, Avus Silver, Ti Package (Sold)
    2014 S4 Monsoon Gray, black optics pakcage (Sold)
    2006 S4 25 Quattro Edition (Sold)
    1976 Audi Fox (Sold)
    Veteran Member Three Rings One Nice Audi's Avatar
    Feb 19 2004
    Massachusetts
    He's selling/sold his car. Not a total loss part out.
    Jun 22 2011
    Milwaukee, WI
    Quote Originally Posted by One Nice Audi View Post
    My mistake. Thanks! (One Nice Audi).
    Veteran Member Three Rings zps123's Avatar
    Apr 20 2012
    MK1 Rabbit 2.0 16v
    is there a difference in lighting output between OEM and Valeo ecodes?
    2015 Audi SQ5
    Brilliant Black|BO|Black Nappa|B&O|NAV|KW HAS
    Past: '14 Audi S4 | '11 VW Tiguan
    Sep 17 2007
    Quote Originally Posted by zps123 View Post
    I do not believe that there is an output difference, however the light beam is at a slightly different angle if I remember correctly. And they look cool, which is the real reason we all buy them....
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    where in ny are you located ?
    Junior Member Two Rings RobClark317's Avatar
    Jan 24 2018
    New Jersey
    Pmed for the rear brake caliper covers.
    2019 RS5 Coupe - Panther Black Crystal
    Veteran Member Three Rings Maddog3xx8's Avatar
    Sep 02 2009
    Ashland MA
    Solid seller! And the car/parts are mint!
    Sent from my SM-G965U using Tapatalk
    B8 SQ5 - 034 Stage 2+ DP Tune / Pulley Ratio 3.209/ 034 ZF Tune / Ported Blower with Port Matched 75mm TB / AWE 102mm Touring Exhaust / AWE Non Res Downpipes / AWE Cold Front HX / ARM 3.5 Intake / V-FF 102s 20x10 / DWS 295/40/20 Square / 12mm Spacers Front & 15mm rears / ST Coilovers / EuroCode front Sways & 034 rear sways/ 034 Links/ EuroCode Alu Kreuz / 034 Mounts / RSNAV 8.8 / P3 Gauge / CF Mirrors / Vosh Front & Rear BBK / SS brake lines
    Jan 11 2018
    14 SQ5, 11 M3, 13 Sti
    Phoenix, Arizona
    pm sent
    Veteran Member Four Rings stereojorge's Avatar
    Oct 15 2013
    2014 Audi S4 P+ DSG, 2015 Audi SQ5 Prestige
    Tampa, Florida
    Ecode lenses have less dimples than standard lenses so the light output is better than OEM!
    '14 Misano Red S4/APR Stage II+ DP ECU+TCU & UC/187mm Crank & AWE 57.55mm SC Pulleys/CMD Charge Chamber Intake/KW V1 Coilovers/EuroCode Sway Bars & AluKreuz/CR-15/034 Trans Mount/Apikol Rear Diff Mount/ECS Rear Diff Carrier Mounts/CMD Test Pipes/AWE Reso.Downpipes/AWE Track Exhaust 102mm Tips/Vossen HF-3 19" x 9.5"/Michelin PS4S'/StopTech Drilled Rotors/Akebono Euro Ceramic Pads/StopTech SS Lines
    Also: 2015 SQ5 Prestige | 2003 A4 Avant Quattro 6MT
    Previous: 2010 S4 P+ | 2008 A4 S-Line
    May 28 2017
    Hi so is the air box for the setup stick or modded in some way? Thanks
    Sep 17 2007
    OP is edited...Stuff is moving fast!
    Quote Originally Posted by Maddog3xx8 View Post
    Thx Bud. Hope all is well.
    Quote Originally Posted by nicsq5 View Post
    Box is modded, as you can see with the cut-out and mesh. Proven to be the most effective gains of all of the CAI's offered, *except an open element in the winter time only...
    Established Member Two Rings Goned's Avatar
    Jan 03 2017
    What is advantage for Modded OEM Intake ?
    Regards
    Sep 17 2007
    Quote Originally Posted by Goned View Post
    Regards
    Airbox based vs Open Intake setups comparison - Unexpected results
    https://r.tapatalk.com/shareLink?sha...1&share_type=t
    Jan 24 2018
    New Jersey
    Hey bud, just seeing if you received my PM for the rear caliper covers?
    Sep 17 2007
    Hi, they're sold.
    Quote Originally Posted by RobClark317 View Post
    Jan 24 2018
    New Jersey
    Quote Originally Posted by S-Fore View Post
    Hi, they're sold.
    Ok, do you remember where you bought them? Or where I can purchase them? Thanks!
    Jun 22 2011
    Milwaukee, WI
    Did you sell the anti sway bars? Thanks.
    Sep 17 2007
    Quote Originally Posted by jnabeel View Post
    One of the only things left...for now.
    Jun 22 2011
    Milwaukee, WI
    PM'd you.
    Sep 17 2007
    BUMP...
    discounted too..
    Sep 17 2007
    Weekend bump for those sweet mirror caps..
    Sep 17 2007
    bump
    Jun 22 2011
    Milwaukee, WI
    Sweet deal. Mirror caps. Bumpy.
