Guys in all seriousness, if the OP wants a pops and bangs file, why all the hate? Too many ppl listen to respond versus listen to understand. Instead ppl start making up bogus stories about "extra" sensors for a pops and bangs on a car already equipped with the file from factory...complete BS!! The big box companies don't have this because they are indeed chasing down 1/4 miles...sucks that 90% of the crowd that own a B8 S4 don't run 1/4 miles to know if their times have even improved. Goes back to my first quote "Listen to respond versus listen to understand", if big companies actually shot for what ppl want in a product, then question's like the OP's would just be answered by saying X company does it.
Uncontrolled misfires cause catalyst damage, controlled misfires DO NOT cause catalyst damage. Uncontrolled misfires would be would be something like an excessively lean mixture or rich mixture. With a lean mix, there's not enough fuel to create the required explosion thus resulting in a misfire that has extreme heat. This tight of misfire WILL help your catalyst if not resolved fast. If you have a rich mixture forcing a misifre, you don't have enough air to create a proper explosion, once the exhaust open you have unburnt fuel enter the exhaust and ignites on the catalysts brink, this will eventually ruin the bring and also saturate it in fuel for it all won't burn off...aka faulting the catalyst.
When you have a controlled misfire like in the F-Type R, they're injecting fuel on the overrun to ignite on the exhaust stroke, that means timing is also being set to fire around 10-20* PAST tdc. So your not sending unburnt fuel into the exhaust to ignite on the pipe/manifold/catalysts..that act of explosion has already occurred and it's set to be around 14.7:1 because it's set fueling is lambda 1, that means the mixture won't be excessive lean nor rich. Now some ppl may comment "an explosion going into the exhaust would damage the catalysts". Well the temperature of the controlled misfire won't be any different than the exhaust gas temp while in closed loop cruising on the highway at 3,000rpm for few hours. If the controlled misfire was so strong and potent, it would damage the turbo compressor shaft bearings in turbo's resulting in premature engine damage for factories. As for the F-Type, it's supercharged and really just uses the pops and bangs to cool down the exhaust temp after a hard pull, it will pop and bang if reved at idle but that's why Jag limits the idle reving rpm to 3,000. It's not to stop ppl from reving and creating pops and bangs at cars and coffee, it's to stop the timing chain from jumping under NO load just to here the pops and bangs at idle :-)
If you want a pops and bangs file, search for company's that tune for client safety and PREFERENCE, versus companies shooting for that big number and low 1/4 time to say "We're the best" .
Hate on my comment if you like..just my 2cents
