Results 1 to 4 of 4
    Apr 04 2018
    '15 tacoma
    Burbank California
    Question Seeking a 3.0t (or a way to fix mine)
    Hello,
    I have a B8 S4- 2010 year with some light modifications.
    A month to a month and a half ago the engine seized up.
    When I took it apart, the fourth bearing on the crank showed signs of having seized and spun.
    This observation combined with metal shavings in the oil pan and a frozen crank lead me to believe
    that it would be cheaper to purchase a new engine than try to fix this one.
    The car was running both TCU and ECU programming, by Unitronic.
    So, I am basically looking for a 3.0 to purchase, hopefully without extreme high miles.
    Also, when I took my engine out I noticed that both my cat's were completely burnt out with no catalyst remaining, but
    the CEL or oxy sensor never threw a code or showed up.
    Thank you!
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    Quote Originally Posted by GLIS4 View Post
    Hello,
    Thank you!
    Can you elaborate more on the issue on the main s4 forum? I'm curious what led to it, any data logging prior (assuming the car would of ran terribly with a blown cat) and mileage/how long on the tune etc. I think this will be very helpful information for our platform.
    Good luck with the repair/new engine, I've seen them around the $3 to $4.5k range from time to time.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Veteran Member Three Rings 968Reckless's Avatar
    Sep 25 2010
    B8.5 S4, Porsche 993, BMW E30 s52 swap, BMW E30 vert, BMW 2002tii, gen 3 tacoma
    Syracuse, NY
    3.0T long block (no supercharger or wiring )
    https://r.tapatalk.com/shareLink?sha...9&share_type=t
    @martino_motorsport
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    Quote Originally Posted by AvusPdx View Post
    He's had a thread up in main forum for a while
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
