Job duration: 15-25min
Job difficulty: medium (sensitive plastic parts that can easily break)
Tools needed:
- Flat head screwdriver
- T20 torx (if not mistaken, or either T15)
Parts list:
- 2x 8E0955431 (plastic shims)
- 2x 5M0955986C (heated water-jet)
Remove the old water jets from under the hood (gently assist with flat head screwdriver)
Unplug water and power connector
Comparison old vs new
First place the new shim on the edge closer to the windscreen
When installing the new jets, the power cable needs to be carefully routed to the opposite side of the jet
When pressing the water jet into position first hook the jet on the metal side of the opening, align the side tabs to the opening and then (with feeling) press the jet down on the side with the plastic shim. When doing so secure the plastic shim with two fingers on each corner so it doesn't "jump out" and falls into the opening (never to be seen again). The jet has to click into position and sit very firmly.
End result
Adjustment of the new jets is a lot easier than the old 2 line jets
