Results 1 to 13 of 13
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    The official and definitive A5/S5/RS5 performance suspension technical guide
    Title says it all. This thread is not about stance or ride comfort but about performance suspension setup for both street and track. It's my hope we can dump lots of technical data in one spot for both OEM and aftermarket parts so the end user can better assess handling changes using aftermarket performance parts.
    As forum members add information, I'll update this post with the latest data and information. Going to build this up over the next few days as I have time so it's very incomplete.
    If you're a manufacturer or vendor, please join the discussion or PM me with technical info that might help the end user.
    Quite simply, suspension in a nutshell is designed to keep your wheels planted on the road. If the road were always perfectly flat, this would be easy. Springs are designed to support the weight of the vehicle going down the road. Dampers are designed to control the spring's motion up and down but they also dampen the sprung and unsprung weight acting on the spring as well. Every spring rate has a frequency, a rate at which it will compress and extend in a given amount of time. This frequency is affected by the mass at either end as well as the overall suspension design.
    If you have an unmodified A5/S5/RS5 and are thinking about modifying the suspension, first take the time to carefully evaluate what you don't like about the way it handles. If you can break it down and compartmentalize different deficiencies, you'll be better able to formulate a plan and select components which will have a positive effect on the car's handling. I usually spend a few months daily driving a car before I decide on suspension (or other) modifications and even take notes.
    I'm at a real disadvantage with my RS5 in that I bought it with several modifications already in place. I drove quite a few RS5's prior but when it's your car, you drive it differently. Evaluating the stock suspension gives you a good baseline to work from.
    I like to build/tune the suspension around the tire/wheel package with the tires being the most important component. You can have a really expensive, complex suspension setup and if your tires can't take advantage of it, it's wasted money. Every time a variable is introduced, and the car's tire does not stay in contact with the road, you're loosing mechanical grip. Shocks too firm? Loosing grip. Sway bars too big? Loosing grip. Spring rates too high for the roads you're driving on? Loosing grip. Mismatched components that don't work well together? Loosing grip.
    Sticky tires will also allow you to run a higher wheel frequency. It'll actually require it.
    Tire choice is a really personal thing. I usually prefer a tire with a more compliant sidewall. I don't pretend to understand the magic but driving on a set of Michelin Pilot Super Sports was a major eye opener. I'd gone from Bridgestones and the amount of bump compliance from the Michelins far better, in a different league. Despite high spring rates and aggressive damping, the tires provided a major improvement in compliance over bumps.
    At the same time, any loss in steering precision or initial turn-in couldn't really be felt. I did think the Bridgestones had a hair more turn-in response at best. I was sort of shocked by this. There didn't seem to be a downside to the "softer" sidewall and the mid corner stability was just as good as the Bridgestones with better traction on exit.
    They were also several pounds lighter each which probably helped reduce the suspension harshness as the damper had an easier time controlling the unsprung mass.
    Roll Center
    Roll Rate
    Natural Frequency-Picture a mass on a spring (with no damper). Push down on the mass and the spring will oscillate up and down at a specific rate until the force dissipates through heat and friction. That's the natural frequency. If you were to drive your car down a road on nothing but springs (no dampers) and hit a bump, the springs would compress and decompress and the car's body would move up and down until the bump force dissipates.
    Wheel Frequency-This is measured in Hz and it's your tire oscillating as you drive down the road. A faster rate gives a harsher ride while a slower rate will feel more plush. When you start getting into the 2hz range, you're on the performance end of the spectrum. A luxury sedan will usually have a rate below 1hz and a high performance sports car will have a wheel frequency in the 2-2.5hz range. An all-out circuit race car may have one even higher in the 3.0hz range. So this rate, more than anything, will tell you how the car will ride before slapping on that new coil-over system. I'm guessing (for now) something like the RS5 has a wheel frequency somewhere in the 1.5hz range for the OEM suspension.
    f = 1/(2π)√(K/M). f=frequency, K=spring rate, M=mass But mass is the total weight minus unsprung weight which includes everything not supported by the spring such as tires, control arms, wheels, brakes, etc...you can physically measure some of the parts and you'll have to make a guesstimate on the rest unless you're willing to disassemble the suspension. The last time I took my front suspension out, I forgot to weigh it. Next time!
    You'll have to corner weight your car to start. From there we have most of the pertinent information assuming you know your spring rate at each corner of the vehicle.
    Motion Ratio-The amount of shock travel for a given amount of wheel travel (think of a lever with different pivot points). Theoretically, since the suspension design is the same for all three models, the motion ratio should be the same. You can test this yourself by jacking up the wheel hub assembly an inch (measured at the spindle centerline) and then measuring the change in distance between the top spring mount and the bottom spring mount.
    A5-
    S5-.628 front, .6 rear
    RS5-
    Wheel Rate- This is the ratio of your shock to wheel travel. This is your effective spring rate once a spring of a certain force is installed on the car. If you have a 500lb spring and a motion ratio of .5, your actual spring rate is 250lb. This is what you feel as a driver when driving down the road.
    Flat Ride Concept-I was introduced to this on another forum and what it essentially revolves around is slowing the front suspension's reaction to a bump and speeding up the rear suspension so that the rebound mechanism causes both wheels to land on the pavement at nearly the same time and vibrate at the same frequency. This supposedly gives you more confidence but I'm not entirely convinced. I think it probably works better on a short wheelbase car like a Miata or AE86 than it does on a longer wheelbase car. The number one goal is to maintain contact with the pavement. I'm sure there's some tradeoff middle ground and a harder rear suspension can send you flying out of the seat. A soft front suspension often doesn't control the spring well enough and introduces more body motion. Greater body motion, shifts in weight, can affect driver confidence and transient response. Damping curves, particularly high speed compression damping, can effectively control body motion to the point where it doesn't impact traction. Flat ride is also supposed to make the ride less "harsh" but it requires a higher rear wheel frequency rate. Generally, the rear is 20% firmer than the front and it does help with different front/rear oscillations, reduces pitch and it feel like the front and rear suspension are reacting to the bump in unison. If the fronts are "vibrating" at one frequency over imperfections and the rears another, this can make the car feel unsettled as the chassis flexes at two different frequencies.
    I can see some benefit to this concept on an AWD, front heavy car. A stiffer rear suspension can help the car rotate much like a firmer rear sway bar does. Everything is cause and effect. But as you want more performance out of your vehicle and value performance over outright comfort, you'll move away from the flat ride concept because you'll want a higher front wheel frequency rate.
    Spring Rates-This
    The factory springs are linear meaning their rate does not change as the spring compresses. Progressive rate springs are just that; as they compress, the spring rate increases but it's not linear. Progressive rate springs seem to be a very popular choice by aftermarket manufacturers for the B8 platform. Racers prefer linear springs as they're more predictable to the driver and easier to "tune".
    Spring rate in lbs/in
    S5 3.0T-480 Front, 200 rear
    RS5
    A5
    A5 Sport
    Sway bars
    OEM RS5 sway bars (Solid)
    Front-28mm (verified)
    Rear-22.5mm
    OEM S5 3.0T (Solid)
    Front-? (26.5mm guess)
    Rear-21.7mm
    OEM S5 4.2L
    Front-26.5mm (to 1/18/2010)
    Front-25.6mm (1/19/2010 on)
    Rear-21.7mm
    OEM A5 (Solid)
    Front-26.5mm (Sport)
    Front-25.6mm (non-sport)
    Rear-21.7mm (Sport?)
    Rear-19.6mm
    H&R (Solid)
    Front-30mm (adjustable)
    Rear-24mm
    Eurocode (Solid, both adjustable)
    Front-32mm
    Rear-25.5mm
    034 Motorsports (Solid)
    Rear (only)-25.4mm (adjustable)
    ST Suspension (Solid)
    Front-28.575mm
    Rear-23.8mm
    GMG (Hollow, adjustable)
    Front-28.6mm (35-85% increase in torsional stiffness)
    Rear-25.5mm (83-120% increase in torsional stiffness)
    Stasis
    Rear-24mm
    Hotchkins (Hollow/adjustable)-Not sure if these’ll fit the 5 but they do fit the B8 4’s.
    Front-32mm
    Rear-25.5
    More later...
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Veteran Member Three Rings Sazexa's Avatar
    Jul 15 2017
    Colorado
    Hey Ape, I don't know how accurate this information is, but I stumbled across this a few days ago.
    http://dreamingin302ci.blogspot.com/...pring.html?m=1
    Jun 24 2017
    San Antonio, TX
    Some of that info is good, some of it I question. It lists the Bilstein PSS10 spring rate but it's a progressive rate spring and Bilstein won't give out that information. I've tried and tried to get even a "ballpark" figure and they won't give it out. So...I take some of the info with a grain of salt. But it's worth posting if nothing ore than for reference.
    Edit: I went back to that link and there's actually some earlier information that's really helpful. I didn't realize it was there. He also mentions my big issue with the aftermarket products available for the B8; he thinks they're all developed with the A4 in mind. He could be right given the number of A cars is far greater than S or RS. From a business standpoint, it makes sense. He also spent quite a bit of time on-track evaluating changes. But he runs mega camber and most of us aren't tracking as much as he is. Probably worth separating the aggressive street setup from a track setup.
    Veteran Member Four Rings RockJGC's Avatar
    Sep 28 2014
    NY/NJ metro area
    LOL
    Aug 17 2017
    2001 Audi TTQC 225, 2003 VW GTI 20thAE, 2016 SQ5
    Atlanta, GA
    Are you going off his assumptions for rear motion ratio? He even comments in the listed thread that it's closer to 1:1, vs 0.6 from his reverse calculations.
    Jun 24 2017
    San Antonio, TX
    FOr. OwnI am until either myself or someone else has time to take measurements. Due to the linkage design and outboard spring, I’m not sure it could be 1:1 which is why I found some of that info confusing.
    Oct 15 2017
    New England
    It would be nice if we could add some knowledge on mating Springs to the shocks (I think there is a relationship in the spring rates/absorption that should be kept in mind when making changes)
    This would be helpful for people to understand the impact of the proposed aftermarket suspension changes.
    Big ups to people who take the time to put info like this together for the rest of us.
    Jun 24 2017
    San Antonio, TX
    Quote Originally Posted by S5Toks View Post
    Definitely going to do this, just haven’t gotten around to it yet. There is most definitely a cause and effect relationship depending on a few variables and type of shock/piston.
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    found what i think are some reliable & helpful links.....
    motion ratio
    measuring the motion ratio
    Spring and Shock Rate Spreadsheet
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Jan 04 2018
    Modesto
    Has anyone been able to confirm the RS5 Front Sway size? The info for the bar seems to be no where online. ECS and various other Audi part dealers do not list it.
    Jan 04 2018
    Modesto
    UPDATE: I was able to solve the mystery by measuring an RS5 Front sway. OEM Size is 28MM.
    Jun 24 2017
    San Antonio, TX
    Sweet! Thanks for the contribution! I've updated the first post.
    Veteran Member Three Rings djnuge's Avatar
    May 15 2015
    Great Info.
