Results 1 to 6 of 6
    Nov 27 2007
    NoCal
    Coolant loss through expansion tank cap?
    My expansion tank cap wasn’t totally sealed and I just got a coolant low warning.
    Is it possible to lose nearly 1/4 a gallon of coolant through evaporation if this cap isn’t totally sealed?
    If so, would I just add distilled water back or a 50:50 mix?
    Ie does the coolant evaporate with the water or just the water?
    Thanks guys.
    May 20 2010
    Over time, sure. Not sure how long it was going, but yeah, definitely over a long period of time.
    You can get away with adding the distilled water at this time of year, as it will continue to get warmer out. But 50:50 is safe. To be safe, you could use a hygrometer (should be relatively cheap) to give you an idea of what the residual mix is.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Nov 27 2007
    NoCal
    Thanks it was probably not completely tightened for a couple of months I’d say.. though I didn’t see any type of overflow or leaking out the cap area.
    Aug 07 2014
    2020 Q8 Prestige,2023 S5 Prem+
    Stanwood, Wa.
    Coolant tanks are prone to develop heat cracks, check there.
    May 20 2010
    At least it's not the "organic" tanks Jaguar was/is using, which tend to become porous over time.
    Senior Member Three Rings Hey_T_S5's Avatar
    Nov 25 2017
    2013 Audi S5 - Totalled
    Allen, TX
    Check for signs of coolant residue around your tank, if it was leaking you should see it. Coolant won’t evaporate that easily but the pressure will make it escape thru any openings like a loose cap or a hole in the radiator. I would refill the tank with the proper solution, run the engine hot and check the system for leaks. Also check the cap on the coolant tank, that’s your first point of failure so it could be that the cap needs to be replaced.
