Results 1 to 12 of 12
    Stage 2 Banner Advertiser Three Rings
    Oct 11 2016
    Montreal, QC
    *Unitronic Stage 3 Dual Pulley Upgrade Kit for 3.0 TFSI - Now Available!*
    Unitronic® is pleased to announce the release of its Stage 3 Crank Pulley Upgrade Kit for the 3.0TFSI* engines. Featuring an impressive increase to [COLOR=red]493 HP/441 lb-ft of torque, Unitronic’s Stage 3 Crank Pulley Upgrade Kit includes its 187 mm Crank Pulley, 7PK1300 Belt, and most importantly, its Stage 3 Dual Pulley Performance Software calibration.
    This can be purchased as an Upgrade Kit for users who already have Unitronic’s Stage 1/1+ Software or Stage 2+ Supercharger Drive Pulley Kit. Or it can be purchased as a complete kit with the Supercharger Drive Pulley.
    Unitronic's Stage 3 Dual Pulley Performance Software calibration is engineered specifically for use with both its Supercharger Drive and Crank Pulleys to ensure maximum performance is achieved while maintaining complete OEM-like reliability and drivability.
    Unitronic strongly recommends combining its Stage 3 Dual Pulley Upgrade with an effective Supercharger Cooling System/Heat Exchanger Upgrade to ensure maximum performance can be achieved and can be achieved repeatably. Through development and testing, Unitronic observed up to a 30 hp variance in engine output based on operating conditions, while using the stock (OEM) heat exchanger, as a result of increased intake air temperatures and associated temperature-based corrections to boost and ignition timing.
    Upgrading the Supercharger Cooling System/Heat Exchanger with an effective upgraded unit will lead to an overall decrease in intake air temperatures, allowing for cooler, more dense air to be ingested by the engine and therefore, no temperature based ECU corrections, leading to better overall performance that can be sustained for longer periods of time where the stock cooling system/heat exchanger would otherwise fall short, suffering from heat soak very quickly when turning the supercharger at such high speeds.
    Unitronic is actively developing and testing solutions to address the stock (OEM) Cooling System/Heat Exchangers/Intercoolers, as we reached the limit on the stock components at these power levels. Unitronic will continue to develop a Supercharger Cooling System/Intercooler solution to allow for us to further develop the 3.0TFSI platform for an even greater increase in engine output.
    FEATURES
    • 187 mm Crank Pulley
    • 6061-T6 Aluminum construction
    • Black anodized finish
    • TDC marking for easy install
    • 7PK1300 belt
    • Genuine Audi crankshaft bolts included
    *Available for B8/B8.5 S4/S5 and SQ5 models only currently. Peak engine output will vary based on the the maximum engine speed limit. Support for C6 A6, C7 A6/A7, A8, Q5, and Q7 is coming soon!
    Unitronic -- Performance Software & Hardware for VW® / Audi® / Porsche®
    Web: www.getunitronic.com
    Tel: 1.866.341.2447
    Follow us on: Facebook / Instagram / Youtube Please note that this account do not accept PMs. For private questions, please email [email protected].
    Veteran Member Three Rings turbojayc's Avatar
    Sep 11 2015
    PUMPED
    Just spoke to my dealer and made sure I was on the list.
    2023 S3 - Daytona Grey Pearl | H&R Sport Spring | 19" Rotiform OZR | Unitronic Stage 1+
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Established Member Two Rings Goned's Avatar
    Jan 03 2017
    Why is not available for Q5 3.0T ??? it's the same engine from SQ5 !
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by turbojayc View Post
    PUMPED
    Great! Tell him to get his order in fast, as they're quite popular!
    Quote Originally Posted by Goned View Post
    Email support [at] getunitronic [dot] com with your ECU Box code if you're not already a Unitronic Client. If you're already a Unitronic Client, your full name and VIN will do! We'll let you know timeframe for your ECU box code.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Veteran Member Four Rings BG SQ5's Avatar
    Feb 21 2016
    '07 CBR1000RR
    PA
    Nice that you guys are joining the fun. What octanes are available?
    Btw I gotta say- not too wild about messing with the nomenclature we've developed as a community. Simply increasing the pulley ratio does not constitute 'stage 3'. It just adds confusion to the market. Just like 93 octane doesn't warrant a '+' (maybe if it was 100 or 104). Sorry, I digress...
    '15 SQ5 Daytona Gray
    APR stage 2 104 oct (e40) - BG TCU (via HPT) - CTS s/c & FD 187 crank - Autotech HPFP - aFe filter/034 tube/modified box - MercRacing h/x - AWE Touring
    21" Forgestar CF10s w/295s - KW Street Comforts - 034 mounts, RSB & end links - ecodes - deAuto LEDs - P3 w/ECA - VCDS
    11.340 @ 120.63 (673 DA) - street trim
    11.012 @ 124.22 (-1346 DA) - track trim
    Instagram: @bg.sq5
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by BG SQ5 View Post
    We currently have a 93 octane map available, but race gas files (VP MS109 or Sunoco 260GT) will be made available soon. If you're interestd in running race gas immediately, shoot me an email to john [at] getunitronic [dot] com and I can work with you as long as you have means to collect some data (data logging). Since our single pulley software was already labeled Stage 2+, we opted to label this as Stage 3. After all, the pulley ratio is above 3 (3.2) with our setup and with the supercharger drive pulley on (Stage 2+), it was below 3 (2.78).
    Sep 11 2015
    Quote Originally Posted by John@Unitronic View Post
    Hey John, apparently they did. Maybe you can put Tom's order from SEM Motorsports at the top of the pile
    2019 SQ5 - RETIRED
    2016 SQ5 - RETIRED
    Apr 29 2014
    2017GLS550 ST1
    Area with Bay people
    Quote Originally Posted by Sales@Unitronic View Post
    Unitronic is pleased to announce the release of its Stage 3 Crank Pulley Upgrade Kit for the 3.0TFSI* engines. Featuring an impressive increase to [COLOR=red]493 HP/441 lb-ft of torque, Unitronic’s Stage 3 Crank Pulley Upgrade Kit includes its 187 mm Crank Pulley, 7PK1300 Belt, and most importantly, its Stage 3 Dual Pulley Performance Software calibration.
    Unitronic is actively developing and testing solutions to address the stock (OEM) Cooling System/Heat Exchangers/Intercoolers, as we reached the limit on the stock components at these power levels. Unitronic will continue to develop a Supecharger Cooling System/Intercooler solution to allow for us to further develop the 3.0TFSI platform for an even greater increase in engine output.
    FEATURES
    • 7PK1300 belt
    Anything for the 18 Q7 ?
    Sent from my SM-N950U using Tapatalk
    For sale: SQ5 springs
    AKA BobSF
    Jan 08 2016
    Los Angeles, California
    Nearly 500 hp is quite impressive.Good work.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    Quote Originally Posted by SQ57 View Post
    "Support for ... Q7 is coming soon!"
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Could you please email us your full vin, vehicle details, and ECU box code to support [at] getunitronic [dot] com?
    Feb 27 2012
    California
    Was quoting the ENTIRE post with pictures necessary?
