Page 1 of 6 123 ... LastLast
Results 1 to 40 of 210
    Stage 2 Banner Advertiser Three Rings
    Oct 11 2016
    Montreal, QC
    *Unitronic Stage 3 Dual Pulley Upgrade Kit for 3.0 TFSI - Now Available!*
    Unitronic® is pleased to announce the release of its Stage 3 Crank Pulley Upgrade Kit for the 3.0TFSI* engines. Featuring an impressive increase to [COLOR=red]493 HP/441 lb-ft of torque, Unitronic’s Stage 3 Crank Pulley Upgrade Kit includes its 187 mm Crank Pulley, 7PK1300 Belt, and most importantly, its Stage 3 Dual Pulley Performance Software calibration.
    This can be purchased as an Upgrade Kit for users who already have Unitronic’s Stage 1/1+ Software or Stage 2+ Supercharger Drive Pulley Kit. Or it can be purchased as a complete kit with the Supercharger Drive Pulley.
    Unitronic's Stage 3 Dual Pulley Performance Software calibration is engineered specifically for use with both its Supercharger Drive and Crank Pulleys to ensure maximum performance is achieved while maintaining complete OEM-like reliability and drivability.
    Unitronic strongly recommends combining its Stage 3 Dual Pulley Upgrade with an effective Supercharger Cooling System/Heat Exchanger Upgrade to ensure maximum performance can be achieved and can be achieved repeatably. Through development and testing, Unitronic observed up to a 30 hp variance in engine output based on operating conditions, while using the stock (OEM) heat exchanger, as a result of increased intake air temperatures and associated temperature-based corrections to boost and ignition timing.
    Upgrading the Supercharger Cooling System/Heat Exchanger with an effective upgraded unit will lead to an overall decrease in intake air temperatures, allowing for cooler, more dense air to be ingested by the engine and therefore, no temperature based ECU corrections, leading to better overall performance that can be sustained for longer periods of time where the stock cooling system/heat exchanger would otherwise fall short, suffering from heat soak very quickly when turning the supercharger at such high speeds.
    Unitronic is actively developing and testing solutions to address the stock (OEM) Cooling System/Heat Exchangers/Intercoolers, as we reached the limit on the stock components at these power levels. Unitronic will continue to develop a Supercharger Cooling System/Intercooler solution to allow for us to further develop the 3.0TFSI platform for an even greater increase in engine output.
    FEATURES
    • 187 mm Crank Pulley
    • 6061-T6 Aluminum construction
    • Black anodized finish
    • TDC marking for easy install
    • 7PK1300 belt
    • Genuine Audi crankshaft bolts included
    *Available for B8/B8.5 S4/S5 and SQ5 models only currently. Peak engine output will vary based on the the maximum engine speed limit. Support for C6 A6, C7 A6/A7, A8, Q5, and Q7 is coming soon!
    Unitronic -- Performance Software & Hardware for VW® / Audi® / Porsche®
    Web: www.getunitronic.com
    Tel: 1.866.341.2447
    Follow us on: Facebook / Instagram / Youtube Please note that this account do not accept PMs. For private questions, please email [email protected].
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    it was about time, those holes in the crank pulley are for weight reduction correct?
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    Awesome!
    So, it’s safe to use without the cooling? I understand it may not make advertised numbers repeatedly... I just want to be clear that it’s safe to do so.... while you guys develop your cooling option(s).
    Thanks.
    Checks PayPal account...
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Aug 31 2017
    SouthEast USA
    Upgrade pricing missing from webpage?
    Mar 05 2004
    NoVA
    Quote Originally Posted by tsitalon1 View Post
    $450 for pulley, belt, software.
    I assume we’d need to pay a dealer time to download the tune. Or cable. You know, for when switching to the race gas program. Hint, hint, nudge, nudge, wink, wink
    SOLD 1995 90
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Couple of questions:
    Are those dyno numbers based on 93 octane fuel?
    What other mods are on the car that ran 493hp?
    What kind of dyno are you using?
    Lastly what is the weight of the pulley?
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Dec 11 2015
    PA
    I saw it was $2,000 on their webpage. Is that $450 for an upgrade over stage 1?
    Aug 31 2017
    SouthEast USA
    Quote Originally Posted by Silver Streakin View Post
    I can't find that, the upgrade pricing only lists *** for stage 3 on my screen :(
    Nov 20 2013
    Montreal Canada
    I see 2150 CAD for dual pulley upgrade kit. Does this include the supercharger pulley? Shows the supercharger pulley in picture but does not appear in the hardware included section.
    Thanks.
    Sent from my SM-G965W using Tapatalk
    Veteran Member Three Rings USAF_Danny's Avatar
    Mar 05 2015
    Supercharged E92 M3, A3 E-Tron
    Orange County, CA
    Gah why must the pricing for your stage 3 be what I paid for a single pulley stage 2.
    YouTube: DV Motions | Instagram: @danny.vuu @undisclosedm3
    []SQ5
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by USAF_Danny View Post
    stage 3 with dual pulley included is 2k?
    you paid 2k for single pulley?
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by maty360414 View Post
    Weight savings, yes.
    Awesome!
    Thanks.
    Yes, it's safe; the ECU will apply corrections for Intake Air Temperature (IAT), so if you're using a stock cooler/heat exchanger, you'll likely float into those corrections.
    It's $450 USD to upgrade from Stage 2+ to Stage 3, and it includes our Stage 3 Software Upgrade, Crank Pulley, Belt, and Crankshaft bolts.
    Quote Originally Posted by Bruno_s4 View Post
    The dyno figures are using 93 octane fuel. No other modifications on the vehicle. We're using a MAHA LPS3000 dyno. Our pulley is 2.0 lbs; 6.6 lbs lighter than OEM.
    Quote Originally Posted by iksnoved25 View Post
    If you're currently Stage 1 or Stage 1+, it is $950 USD ($1050 CAD) and includes the Stage 3 Software Upgrade, Supercharger Drive Pulley, Crank Pulley, Belt, and Crankshaft bolts.
    If you're currently Stage 2+, it is $450 USD ($550 CAD) and includes the Stage 3 Software Upgrade, Crank Pulley, Belt, and Crankshaft bolts.
    If you're currently stock, it is $2000 USD ($2150 CAD) to go straight to Stage 3 and includes the Stage 3 Software, Supercharger Drive Pulley, Crank Pulley, Belt, and Crankshaft bolts.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Senior Member Three Rings sc117's Avatar
    May 11 2015
    2015 Audi SQ5
    NOVA
    I'm ready for Stage 3!
    Since Unitronics currently does not offer a Supercharger Cooling System/Heat Exchanger Upgrade, which system is recommended?
    Mar 20 2018
    1991 Audi 200 20v Avant
    Broomfield, CO
    $2k to go dual pulley from stock is a pretty good deal if you compare to EPL and APR, they'll both run you $2k+ for software then you have to buy a crank pulley. I'll be upgrading as soon as I've got some spare change.
    2012 S4 6MT glacier white metallic. Unitronic Stage 2+, custom intake, AWE touring exhaust
    1991 Audi 200 20v Avant titanium grey. K24-7400, VEMS, custom everything.
    1991 Audi 200 20v Avant pearl white. EFR 6758 - project status
    Nov 20 2013
    Montreal Canada
    Quote Originally Posted by efredrick View Post
    Don't forget to add around 800$ for the dsg tune if you are not manual. EPL is still cheaper when they have their sales.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    now we just need some unitronic cooling options
    Mar 20 2018
    Broomfield, CO
    Quote Originally Posted by mantech4 View Post
    Unless you don't have a DSG...
    Nov 20 2013
    Montreal Canada
    That's what I said. "if you are not manual"
    Mar 20 2018
    Broomfield, CO
    Ah, missed that part. At any rate, it is competitively priced, plus you can bank on 10% off or so when they have a sale.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by chopz33 View Post
    Working on it
    Mar 05 2015
    Orange County, CA
    I paid 2k for a stage 2 single pulley 93 file + TCU tune from EPL.
    []SQ5
    Sep 22 2013
    Quote Originally Posted by John@Unitronic View Post
    What's the price of TCU tune?
    Veteran Member Four Rings RLB6's Avatar
    Sep 20 2006
    '05 MV Agusta F4-1000
    MD
    'bout time....I see another vendor going with a "non-dampered" crank pulley. Maybe there is no issue going dampened vs non-damped.
    Current: '23 etron-GT | Prestige
    Previous: S5 | Prestige
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by Dardan View Post
    Our Stage 2 TCU software is $850. If you combine the ECU+TCU software purchases together, you can save $150 on the DSG, reducing it to $700.
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    its about time!!
    ha ha just joking, glad that everyone is able to enjoy this tune :)
    if anyone has any questions i would be glad to answer via pm ;)
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings A.C.'s Avatar
    Sep 15 2013
    2015 VW GSW TDI, 2004 GLI, 2015 Kia Sorento
    MD
    I currently have the overdrive crank with the same diameter including the Stage 2+ software. What’s the cause of just upgrading the tune?
    Jul 21 2004
    South Florida
    Congrats you guys. You're going to have some fun with those files. Even as an early adopter I can say in 100% honesty that I never had a hiccup on any of the beta files. Not a single negative driveability issue that had to ever be corrected. It was literally just dialing up the power in the revisions. Great job getting the product out John. I know you had / have a lot of competing projects.
    Mike
    2018 Audi S5
    Gone-
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Working on it
    I’ll be the test dummy...haha I’m stage 2dsg and tcu. Guess I will wait and see what options I have for cooling.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by bhvrdr View Post
    Mike
    Thanks Mike! It was a pleasure to work with you back in the early BETA stages. I'd love for you to experience the final release product. I know you don't have your 3.0TFSI anymore, but we have to find a way to get you some seat time in the production files. It's quite a bit better than it was back then. Thanks for your kinds words Mike! Stay in touch!
    Quote Originally Posted by A.C. View Post
    $1650 USD for just our Stage 3 ECU Software without hardware. Keep in mind our Stage 3 ECU Software is calibrated for a 3.2 ratio.
    Sep 15 2013
    MD
    Thanks John. Excuse the typo.
    Veteran Member Three Rings importraceram's Avatar
    Feb 20 2012
    e90 M3
    NH
    This is still flash at home correct?
    Current: 2010 Meteor Gray S4 6MT- APR Stage 2, XLR8 196.5mm Crank Pulley, MercRacing HX, CTS Intake
    Past: B7 S4, B8.5 S4, B7 RS4
    Veteran Member Three Rings Strong Man's Avatar
    Jan 24 2017
    woowwww...it's hard to believe ... I was waiting for that for almost a year...and I have to tell you guys , that I'm running UNI full ST2 + TCU for almost a year include autocross and track-days events - so far ZERO issues...my car push really hard...easy leave behind mustang 5.0
    That's exactly on time , I've just done PLM HX three weeks ago !
    John , any chance to get some extra discount for these who is doing ST3 during less than a year from ST2?
    2013 Audi S5 3.0T: Custom Audison with B&O, Quattro Sport Differential, ADS, 7-speed dual-clutch DL501
    Mods: ||ST2: Unitronic ECU + TCU + Ported SC & Throttle||Intake: ESC Kohlefaser Luft ||Exhaust: AWE Touring with Resonated DPs 102mm tips||Susp:CR15, Alu K, H&R OE, H&R R Sway Bar, ECS Drv Mnt Insert Kit ||H&R Spacers: 15F/20R || Brakes: ECS SS Lines, StopTech BBK Creo Slott Rotors F/R, HAWK 5.0 F/R, Motul 600 || etc.
    Mar 12 2010
    Guys just remember that your stock cats are going to get toasted.... It's just a matter of time.
    Sent from my Samsung S8+
    Sep 15 2013
    MD
    Mike
    Mike, Thanks for the tip for Tampa Motorsports. I finally talked to John (I believe) not Evan about the test pipes or HFC. Very helpful guys and will go that route. Also contemplating their supercharger porting and heat coating. Now I have to find out if Unitronic has a file for the O2 sensor to alleviate the CEL.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by importraceram View Post
    Yes, of course.
    Quote Originally Posted by Strong Man View Post
    No, sorry. Our Stage 3 pricing is as competitive as it gets pretty much.
    We've had this in BETA with this for over 2 years and haven't experienced any issues with any of our BETA cars, including one of them that has over 250,000km and counting on the original OEM cats.
    If you're removing the factory cats with test pipes, we'll need to do much more than just patch the catalyst efficiency codes. Email me for more details; john [at] getunitronic [dot] com.
    Sep 15 2013
    MD
    If you're removing the factory cats with test pipes, we'll need to do much more than just patch the catalyst efficiency codes. Email me for more details; john [at] getunitronic [dot] com.[/QUOTE]
    Thanks John. I’ll send you an email shortly of what I have in store this summer
    Jan 24 2017
    So , John , you're saying that we should NOT be worried about that with ST3 we're going to burn out our cats ?! There are many topics on this forum that people complain about burned cats as results of high tune.
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    I'm saying that we haven't encountered any as mentioned in my previous post.
    Sent from my SM-G950U1 using Tapatalk
    Active Member Two Rings SOURKRT's Avatar
    Apr 02 2018
    2012 S4
    Greensboro/North Carolina
    Is this with stock fueling or is an aftermarket hpfp or lpfp upgrade required?
    Nov 02 2015
    Orlando, FL
    You’re going to eventually burn out the cats going dual pulley. This shouldn’t be news to anyone.
