Results 1 to 19 of 19
    Veteran Member Three Rings GTA_G20's Avatar
    Jan 25 2018
    2004 Boxster S 550 SE
    St Catharines
    Engine cranks but won't fire - No start
    So the car was running and had a clicking noise and sounded like it was running on 3 cylinders. Now it won't start at all. Please ignore the low voltage. I cranked it to death. It's back on a tender
    001112 - Evap System Purge Control Valve (N80)
    P0458 - 002 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 127220 km
    Time Indication: 0
    Freeze Frame:
    RPM: 151 /min
    Load: 85.1 %
    Speed: 0.0 km/h
    Temperature: -2.0°C
    Temperature: 0.0°C
    Absolute Pres.: 980.0 mbar
    Voltage: 10.287 V
    000581 - Solenoid Valve for Boost Pressure Control (N75)
    P0245 - 002 - Short to Ground - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 127220 km
    Time Indication: 0
    Freeze Frame:
    RPM: 151 /min
    Load: 85.1 %
    Speed: 0.0 km/h
    Temperature: -2.0°C
    Temperature: 0.0°C
    Voltage: 9.779 V
    009217 - EVAP Leak Detection Pump Control Circuit
    P2401 - 002 - Short to GND - Intermittent
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 127220 km
    Time Indication: 0
    Freeze Frame:
    RPM: 150 /min
    Load: 85.5 %
    Speed: 0.0 km/h
    Temperature: -2.0°C
    Temperature: 0.0°C
    Voltage: 9.906 V
    008853 - Fuel Pressure Regulator Valve (N276)
    P2295 - 002 - Short to Ground
    Freeze Frame:
    Fault Status: 01100010
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 127220 km
    Time Indication: 0
    Freeze Frame:
    RPM: 86 /min
    Load: 85.1 %
    Speed: 0.0 km/h
    Temperature: 2.0°C
    Temperature: 9.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 8.382 V
    005634 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Load: 0.0 %
    Speed: 0.0 km/h
    Temperature: -40.0°C
    Absolute Pres.: 0.0 mbar
    Voltage: 0.000 V
    Readiness: 0110 0101
    Any help is appreciated
    Sent from my E2306 using Audizine mobile app
    2005 Audi A4 1.8T Quattro(Gone), 2006 Audi A4 Avant 2.0 Quattro(Gone), 2004 Porsche Boxster S 550 Spyder SE, 2012 Audi A4 Quattro
    Feb 15 2016
    Cambridge,Ontario
    with these cars with those symptoms I would just go back to basics.
    see if you have spark and fuel , then check compression ...
    ok knowing what I know forget the other stuff, just do a compression check ..
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    When you turn the key to position 2 do you hear the fuel pump prime? Do you have fuel pressure at the fuel rail (press in the shrader valve and see if fuel squirts out or dribbles)? Next as stated above I'd check for spark.
    Jan 25 2018
    St Catharines
    Definitely have compression. I do hear the fuel pump but to check for spark I was told never to check coil packs outside of the cylinder it's meant to be placed in
    Veteran Member Four Rings canadianA4B7's Avatar
    Feb 10 2012
    parts
    Napanee, ON
    Fuse or relay?
    Possibly the stupid one under the ECU.
    Jan 16 2016
    indiana
    Well i recently had a similar problem. Car would randomly not start. I could hear the fuel pump turn on everytime so i knew that was fine. The car would crank and crank and I would crank it like 5 or 6 times before it would finally turn on. Did this to me at random times during a good two months ( probably seven or eight times). It was a bad relay. So I replaced all three like a month ago and ive been good since.
    Jan 25 2018
    St Catharines
    How do I remove the ecu box cover without breaking it. Seems like a foolish design or maybe I'm the fool
    Veteran Member Three Rings mgfranz's Avatar
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by GTA_G20 View Post
    You have to remove the wiper arms then you can remove the cowl shield. Once you remove the cowl you can get to the back screw, then it's easy from there.
    2008 Audi B7
    2003 Ford F250 XLT
    2001 Porsche Boxster
    1999 BMW 740i M-Sport GONE
    Jan 25 2018
    St Catharines
    Ahhh. I went to the wreckers today and pulled an n80 n275 and the fuses and relays. I snapped the lid off. But now I know better.
    Jan 16 2016
    indiana
    Quote Originally Posted by mgfranz View Post
    exactly what he said. I will say though, my wiper arms were stuck on there. Probably were never removed in the life of the car (11 years). Go buy that wiper arm remover (I paid $25 at oriellys for it), it pops them right off. Also, one of my relays was stuck in there so just be patent and careful
    Jan 25 2018
    St Catharines
    Are both relays needing to be changed or....
    I also noticed two of them were the same part number. And then there was a slim relay.
    Apr 08 2016
    Mission Viejo, CA
    Quote Originally Posted by audiman91 View Post
    I got mine off fleabay for like $7.
    Replace all of them while your in there.
    Jan 16 2016
    indiana
    even better. and yes get all relays replaced
    Aug 10 2011
    330i ZHP
    Before you get in to trouble shooting relays, do you have spark? Although you hear the pump prime do you have fuel pressure and/or do you know when the fuel filter was changed? Have you tried starting it in neutral (not sure if this is an automatic). You can hear the fuel pump and the car cranks so what relay were you suspecting would be causing a no start?
    Jan 25 2018
    St Catharines
    I have no documentation on fuel filter ever being changed. I purchased this car as is and it was sort of running when I purchased it. I towed it home and its been siting since and has not started since the day I purchased it.
    The car is auto and doesnt start in Park or neutral.
    The reason for the relay change/check was due to the fault codes being 'short to ground' and a few people have suspected a fuse or relay beneath the DME. I have never opened that compartment so might as well check it before I start replacing larger items which arent the easiest to replace
    Aug 10 2011
    330i ZHP
    Ah right, the codes, da. I spent a looonng time sorting through a no crank issue recently on a car that ran completely fine the day before so I've been down that road. If you don't have a wiper arm puller I've found if you remove the bolt, then re-tighten it a couple of turns and tap it with a hammer while pulling straight up on the arm then they will generally come off pretty easy, a little liquid wrench for good measure.
    Jan 25 2018
    St Catharines
    Thanks. I'll give it a whirl
    Feb 15 2016
    Cambridge,Ontario
    Quote Originally Posted by MacFady View Post
    keep in mind he does not have a no crank issue, its cranking , he has a no start issue.
    1976 Yamaha XS 360
    Jan 16 2016
    indiana
    yes the two square looking ones are identical. there are four prongs on a relay and each prong has a different number so make sure the new ones go in the exact same way. Take a pic before you pull them out
