Dreams come and go and it’s time for this one to go away from me. I would obviously like to sell as an entire kit. This is virtually 4 years of collecting parts to make this swap a possibility. 15k for everything, I will partout if everything gets accounted for.
Email- [email protected]
Phone-719-494-6814 I work 6-6 m-f and have a 7mo old, please text first before blowing my phone up with calls.
Needs: intercooler pipe fabbed
Pressure plate
Coolant hoses made to and from radiator/heater core
Turbo Oil feed and drain
Oil pan needs tapped
Couple odds and ends
Vr6 12v to b5 s4 Bische harness
12v Vr6 motor stock engine code aaa
034 adapter plate
034starter
034 engine cradle,
Comp turbo 6662 B.B.
SPA exhaust manifold
Spare Vr6 block machined by Schimmel Performance
Spare Vr6 head port job done by Schimmel Performance
Polished and flux coated crank Schimmel Performance
Techtonics tuning valve Springs
Oem calico coated main bearings
Eagle H beam rods
Wisco piston set
Fererra 3mm over intake and exhaust valves
Custom maf housing
Vr6 ignition box
Vr6ignition coils,
Vr6 ecs coolant hose kit
034 intake manifold Vr6
Billy BOB exchaust with downpip and external wastegste dump
Turbosmart 38mm Wastegate with two springs
Tial bov
Spal Electric fans
Bosch ev14 1800 cc injectors
034 fuel rail
Two Bosch 044 pumps
034 duel surge tank
Stoptech brakes st40 332mm
Rear bbk Brembo
Vogtland Coilovers 8k Miles
Spec stage 4 clutch
034 flywheel
Intercooler and piping
Custom ac lines
Custom power steering lines
