I am trying to figure out what is wrong with my C7 CGXB 3.0TFSI.
Car is working good, but i usually see some malfunctions in engine group:
6318 - Leak in Air Intake System
P2279 00 [109] - -
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 96495 km
Date: 2018.11.04
Time: 21:16:41
6307 - MAP/MAF <-> Throttle Position Correlation
P0068 00 [237] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 96495 km
Date: 2018.11.04
Time: 21:16:41
6262 - Idle Control System RPM
P0507 00 [039] - Higher than Expected.
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 97269 km
Date: 2018.05.09
Time: 21:42:03
Sometimes Check Engine appears, then i feel some rough on idle rpms.
I changed spark plugs, change air filter to bosch. I check vacuum valve in rear view of engine. I don't hear any hiss from vacums.
I also performed throttle body adaptation (status OK).
Already checked:
1. throttle body cleaning and adaptation && replacement with another TB
2. checked evap valve (checked under 12V)
3. checked flap valve and SAI valves (checked under 12V)
4. checked SAI (its blowing air into engine)
5. checked vacum on valves in rear of engine (quite hard vacum on idle rpm)
6. new air filter (bosch) + engine oil
7. checked vacum lines (i don't hear potential leakage)
8. new spark plugs
9. PCV module (checked on idle that is possible to remove oil cap, just little vacum)
10. All fuses ok.
11. New PCV module "547AC"
Any ideas, what should i check?
Fault codes appears when car is warm/cold and when i am driving. When i stop the car, iddle rpm jumps to 1100rpm. I feel idle rough. Sometimes its jump from 900-1100.
