Results 1 to 14 of 14
    Feb 26 2015
    United States
    Upgrading to the K04... questions
    I am currently about to drop my K03 and install a K04. I want to use my current cat, for now, and I am wondering if the K04 will fit on a OE cat.
    Jan 04 2014
    US
    if it is K04-15, yes.
    B6 04' A4 1.8TQ 6MT
    Feb 26 2015
    United States
    Thanks
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    The K04-015 is a K03 with a 1-2mm larger compressor wheel (cant remember). All of the stock components will work (manifold, inlet pipe, etc) as it is designed as a mild upgrade over stock.
    Expect about 15 extra peak HP over a K03 with a "big injector" tune, and a slightly more broad powerband.
    2019 SQ5 Prestige
    Veteran Member Four Rings jonan's Avatar
    Nov 25 2006
    2X B7 RS4 - STG III B6 A4 (gone, but still in the family) - Mini R56 S - '15 Macan S - 997.1
    Austin, TX
    k04 is a gateway drug to bigger turbo land...
    Want my guns??? ΜΟΛΩΝ ΛΑΒΕ!!!
    B6 Mods:
    Fully Built Motor w/ GT2860RS and all supporting mods : My Build Thread
    RS4 Mods (sprint):
    RNS-e MKII : ECS SS : JHM Spacers : Deflapped IM : UM Tune : KW V3s : Tubi Rumore : Hotchkiss F&R SBs : 034 Diff Inserts : Phil Special Headlights w/ STI Lenses : 10 Layers : Spare 07BNS (#masterrace) : Apikol Diff & Trans Mount
    Jan 04 2014
    US
    wanna sell my K04 upgrade to bigger......
    B6 04' A4 1.8TQ 6MT
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by uzone02 View Post
    lol, i've had my k04 for less than a month and am already ordering a GTRS, rods, injectors, and a motoza tune...
    B6 Mods:
    RS4 Mods (sprint):
    Veteran Member Three Rings PSI NRG's Avatar
    Feb 24 2008
    It is indeed a gateway to more power lol. I love how my car pulls so hard off the line and around the city with the K04, but definitely leaves you wanting more up top. I know if I want over 300ft/lbs+ I'll have to do rods so its just a matter of committing to tearing everything down to support something bigger. I'm running 440's on a custom Malone tune so I should be OK on fueling but it'll probably run better on a 550 since the spray pattern is better for our 5v head.
    Nov 25 2006
    Austin, TX
    Quote Originally Posted by PSI NRG View Post
    yea, i'm going with 550 injectors and the stock fuel pump with motoza...can't wait till all my shit comes in...
    sucks though, cause i'll be travelling A LOT for work until the end of june so i won't have time to install everything...i'm going to put together a comprehensive word doc with all of the bentley/hayes illustrations, torque specs, clearances, etc while i'm on the road to keep me busy until then...that way i can go into the job confidently since i've never tore a motor apart before...
    B6 Mods:
    RS4 Mods (sprint):
    Feb 24 2008
    Quote Originally Posted by jonan View Post
    Sounds like a solid plan of attack. 1.8's are easy. There's a bunch of youtube videos on how to tear them down and rebuild. Might be worth checking out if you want to give yourself a break from the word doc
    Nov 25 2006
    Austin, TX
    already watched a few of those videos...my dad was a naval engineer so he was big on the whole measure twice cut once thing...the word doc is mainly for my own confidence going into the job and to make sure i don't mess anything up when going through the checklist of things to do...
    B6 Mods:
    RS4 Mods (sprint):
    Senior Member Three Rings sleepwalker_gsr's Avatar
    Jul 08 2010
    Your mom, tied up.....
    sacramento CA
    Quote Originally Posted by fishstick41 View Post
    Dont install a K04! save ur cash and get a GT series or something. WAY better. I had a ko4 and it was a waste. IMO
    2003 B6: GT2871R turbo, Snow Performance Water Meth, Motoza tune, FMIC, Straight pipe, ECS RA4 Stage2 Clutch, 034 fuel pump, 034 TIP, Bosch 550cc injectors, fuel rail, 008 DV, Carbonio intake, coilovers, S4 door blades, USP front bumper and painted lowers.
    Jan 04 2014
    US
    Quote Originally Posted by sleepwalker_gsr View Post
    but for who usually drive in city
    K04 is still a good little step up from ground
    Quick spool, peak at 4k and slowly drop
    DM me if you want it.
    B6 04' A4 1.8TQ 6MT
    Jul 08 2010
    sacramento CA
    A GT2871r is much better than K04 in almost every way. Only thing i'm not a fan of is the lag but once it hits its awesome. still able to DD and you'll save money in the long term because ur not buying another turbo when you want to upgrade again. the most HP you can really expect is 200 to the wheels with the GT im at 260 WHP. Worth it imo.
