Results 1 to 3 of 3
    Jul 15 2014
    Cape Breton Island
    Power steering woes
    My b6 s4 had the PS lines blow out, then the rack seals shortly after, I replaced both HP lines and put in a low mileage B7 s4 DTM rack in, 10k later the seal on the rack let go on one side and won’t hold a drop of fluid.
    Who else have the same issues???
    Veteran Member Three Rings badger.'s Avatar
    Mar 31 2014
    '05 S4 Sedan | '05 S4 Avant | '01 Lexus IS300
    KY
    Where did you get the replacement rack?
    '05 S4 Sedan Arctic White: JHM Intake Spacers | JHM ATF Cooler | JHM Auto-tensioner | 034 Motor Mounts | Apikol Snub | Slotted & Dimpled Rotors | AQ1200D w/Dual 10" CVRs | 35% Tint | Piggies | Fast Intentions Catback
    '05 S4 Avant Brilliant Red: JHM Tune | JHM v1 Headers | JHM LWCP | JHM Ported IM| JHM ATF Cooler | Koni Yellows | Apikol Rear Diff & Snub | Thor Skid Plate | JHM LW Rotors | Fast Intentions Catback
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI B6 S4 Avant 84 Adventurewagen
    VT
    I have had this problem.
    -justin
