Results 1 to 3 of 3
    Jul 15 2014
    Cape Breton Island
    Power steering woes
    My b6 s4 had the PS lines blow out, then the rack seals shortly after, I replaced both HP lines and put in a low mileage B7 s4 DTM rack in, 10k later the seal on the rack let go on one side and won’t hold a drop of fluid.
    Who else have the same issues???
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    Where did you get the replacement rack?
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Veteran Member Three Rings justinperkins's Avatar
    May 14 2009
    Q7 TDI | B6 S4 Avant MT | 84 Adventurewagen | 53 Ford Jubilee
    MI
    I have had this problem.
    -justin
