17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
P1347 - 001 - Incor. Correl.
17748 - Camshaft Position Sensor (G40) / Egnine Speed Sensor (G28)
P1340 - 001 - Incor. Correlation
After doing a little digging through the instructions I realized I didn't do the part where you turn the crank back 45 degrees and put the wedges in. I just had the crank pin in, the 2 cam alignments plates, and used the little tools to line up the hall effect sensors and then tightened everything. Does the engine need to come back out to fix the cam positions or can I do that in-car?
Really upset at myself right now
