Results 1 to 12 of 12
    Veteran Member Three Rings cjw's Avatar
    Aug 11 2015
    Alberta
    Dumb Spacer Question
    I ordered some forged hubcentric 10mm spacers. Is it normal for the first use to need to torque the bolts like 20 times?
    I torqued the bolts in a star pattern, but every time one was torqued, the others were loose. Had to go over and over and over for them to all be torqued. I'm thinking this might just be on first use and they are now seated and shouldn't be an issue - just curious.
    2013 Lava Grey S4 S-Tronic
    Injen, EPL DP (3.2 ratio) +TCU, Magnaflow Catback Back to Stock, PLM HX
    Registered User Four Rings Skyler@Achtuning's Avatar
    Feb 14 2007
    Redmond WA
    Something sounds very wrong here. What brand are the spacers and are you putting them on stock wheels or aftermarket? What bolts are you using?
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by cjw View Post
    Sounds to me like there was an interference fit that was not allowing the wheel/spacer/hub to sandwich together easily, and you were incrementally overcoming the interference by tightening each bolt until the wheel+spacer+hub were finally bottomed out on each other. The spacer should be a close slide fit onto the hub, and the wheel should be a close slide fit onto the spacer. It should not take any force to fit one piece onto/into the other. Can you confirm that this is how everything fit together?
    SOLD 2015 Daytona Gray S4
    Aug 11 2015
    Alberta
    It slid on and didn't look to have any fitment issue, but I'm not sure if there was just a bit of friction from some light corrosion or not. It's not like they snaped into place. No issues with ride quality or anything.
    They are Bloxsport from Ebay (https://www.ebay.com/itm/4-Pcs-10MM-...RalQls&vxp=mtr)
    M14x1.5 bolts, stock rotor wheels, torqued to 90 ft-lbs.
    Oct 14 2012
    Empty...for now...
    SE PA
    Can you confirm the bolts are spherical seat (OEM type)?
    Veteran Member Three Rings AvusPdx's Avatar
    Jan 17 2015
    Portland, OR
    cone seat vs ball seat lug bolts. Need to check them asap. Made this mistake a while back (using a cone seat for a ball seat wheels), I noticed a wobble and I only had 3 lug bolts left, one snapped and one was finger loose.
    Current - Audi B8.5 S4 2013, Mercedes Benz GLE350 2016, Volvo XC60 T5 2015
    Mods - H&R RSS Clubsport, APR stage 2 + pulley, Roc Euro intake, AWE Touring 90mm, ECS RS4 Gloss Black Grill, VMR V705 19x8.5 matte black, Blizzak LM32 225/40/19 (winter) OEM Q5 Peelers 20x8.5 et33, Dunlop Sportmaxx 245/35/20, EBC Slotted/Drilled rotors F/R, EBC redstuff brake pads, Motul RBF 600 brake fluid, Enlaes rear CF spoiler, LED interior light swap, LED fogs, H&R rear sways,
    Aug 11 2015
    Alberta
    They are ball seat and match the stickers.
    Aug 11 2015
    Alberta
    I'll pull a wheel tomorrow and check everything's normal.
    Aug 11 2015
    Alberta
    FFS, I pulled a wheel, the wheel looks fine. The spacers are stuck on and look to have a hairline crack on the hub. If I had to guess, they got the hub bore too small. I'm not sure by how much would cause this. They even asked me to confirm the model and year of my car.
    Now I have to figure how to get these off. A rubber mallet and screwdriver couldn't do it.
    Rage. Any tips to get these off? Looks like YouTube has a few videos.
    Oct 14 2012
    Empty...for now...
    SE PA
    I had a set of metal hub centering rings with slightly undersized bore on my 350z years ago. I took the wheels off and the rings were essentially pressed onto the hub. Come to think of it, I had the same symptom you reported when torquing the lug bolts....had to go around multiple times tightening incrementally to get the wheel to seat. Anyway, these were just hub rings so I used a Dremel tool with carbide cutting bit to cut through the rings and when the remaining material was thin enough the hoop stress in the part overcame the strength and they popped off. In your case you'll have a lot more material to cut off so it may not be viable.
    I would take it to a shop and see what they say. Maybe they can put a torch on it around the center area to expand it enough to ease up the interference fit and allow them to pry/tap them off. It would be nice to leave the spacers intact so you can return them to the vendor for investigation and refund.
    Dec 10 2012
    New York
    Oh how you've fallen into the cheap Chinese spacer trap. Actual hub-centric bore on our car is 66.56mm. The ebay listing said 66.5mm. That's why ECS and other reputable companies sell a 66.6mm bore. Did you really save anything on cheap spacers now that you have to invest all this time to correct the issue?
    Your best bet is to heat the spacer with a torch so it expands. I've also seen extra large gear pullers work if all else fails.
    https://www.ecstuning.com/News/AUDI_...011_2012_2013/
    Aug 11 2015
    Alberta
    Thanks for the condescension, but this wasn't cheap. I searched a few vendors and the shipping options to Canada were crazy. I also don't think this is a tenth of a mm issue. I think it's off by a bit more.
    I'll get a torch.
