Results 1 to 7 of 7
    Senior Member Three Rings p8nt's Avatar
    Jun 05 2010
    Traverse City
    c5 HID - Auto level headlight - passenger side
    Need one to correct recent fender bender, please PM if you have one to sell.
    Then - 04 DG USP 6MT
    Now - 02 Avus Sliver S6
    May 20 2010
    I know I have a spare but forget what side. Can let you know when I get home.
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Jun 05 2010
    Traverse City
    That would be great, thank you.
    - - - Updated - - -
    Did all HID headlights have auto level, or was that another option?
    May 20 2010
    Hey man, wrong side.
    Regarding leveling, I believe all HIDs auto-leveled due to laws, at least in the US.
    Jun 05 2010
    Traverse City
    Thank you anyway!
    Established Member Two Rings Bigglezworth's Avatar
    Jul 16 2012
    Pair of '03 RS6 Saloons, '02 S6 Avant, '91 NSX, & '87 GNX
    Calgary,AB
    Auto leveling has to do with added load. By that I mean that if a car is set up with a driver, the lights are at a certain level. When you load up the trunk, or add more people, the load level of the car changes and that can see light beams alter (this is why there is a sensor mounted to the front and rear suspension both). Auto level is intended to account for those added loads by adjusting the beam when you alter the base setting.
    02 S6 Avant w/ no stuff - Pokey
    03 RS6 Saloon w/ stuff - quick
    03 RS6 Saloon w/ MORE stuff - super quick
    91 NSX CDN issue w/ 6spd & BBSC - quicker yet
    87 Buick OEM GNX clone w/ LOTS of go fast goodies- quickest
    May 20 2010
    Quote Originally Posted by Bigglezworth View Post
    Correct. The allroad added to this because its air suspension. With each corner being able to raise or lower via both user choice (level control switch) or via load, there are level sensors on all 4 corners. With added load, the allroad will also raise itself up to compensate, or lower itself when said load is removed.
