Results 1 to 21 of 21
    Veteran Member Four Rings fmzip's Avatar
    Aug 21 2017
    Vagcom Coding.....Do you guys use a battery charger as suggested??
    Just curious if you guys do and if so, what to use?
    The one in their video looks like its pretty robust. Wondering if there is one that are better than others, rather not cause any havoc with the electronics
    https://www.youtube.com/watch?annota...&v=zFZJj39FZ3s
    BMW M850i
    Oct 14 2012
    Empty...for now...
    SE PA
    I've used VCDS quite a bit and never used a battery charger. It seems a bit overkill to me unless you're going to be doing a lot of coding at once (i.e. spending a lot of time sitting there with the car in the 'On' position but not running), or if you know your battery is failing already.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Only time I ever used one with Vag-Com is when doing rear brakes for the first time, as I took it slow. Next time, might not even bother since it should go much quicker.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Aug 21 2017
    Quote Originally Posted by sacandagaD View Post
    That's exactly what I am doing.....
    I'd prefer to be wise, I have no crystal ball as to when the battery would die..
    BMW M850i
    Jul 02 2013
    Quote Originally Posted by fmzip View Post
    Probably good idea with this wacky winter and spring. I just used a Battery Tender on mine.
    Senior Member Three Rings A4_n00b's Avatar
    May 27 2007
    Pittsburgh, Pa.
    Haven’t done this procedure, but they way they are so ardently pounding it home to use one I’d err on the side of caution and do it.
    Costly and inconvenient mistake could happen if you don’t, so why roll the dice?
    Current: 16 VW Tiguan R-Line 4MO, 15 VW GTI PP, 14 Audi S4
    Retired: 12 VW GTI, 10 Audi S4, 08 VWJetta Wolfsburg, 04 Audi allroad 4.2, 04 VW Jetta, 03 Audi A4 3.0
    Current:
    2022 Audi S3, 2023 Audi SQ5
    Retired:
    2003 Audi A4 3.0, 2004 Audi allroad 4.2, 2004 VW Jetta, 2008 VW Jetta Wolfsburg, 2010 Audi S4, 2012 VW GTI, 2014 Audi S4, 2015 VW GTI PP, 2016 VW Tiguan R-Line 4MO, 2018 Audi S3, 2018 Audi SQ5
    Veteran Member Three Rings seandon_792's Avatar
    Aug 12 2015
    Waldorf, MD, US
    Well if you already have vagcom you can just check your voltage beforehand and get an idea of what state your battery is currently in and make a sound decision from there
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    I only hook the battery charger up when flashing software.
    Sent from my SM-G930VC using Tapatalk
    2021 Audi S4, P34 Intake
    Apr 05 2016
    Portland, OR
    I don't bother... I don't even bother while flashing the car.
    I just turn everything off (headlights, radio, fans) and all is fine.
    If anything is taking longer than an hour you are doing it wrong.
    Note: When doing rear brakes you can turn the car off after opening the EPB.
    Geoff
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    I have a radar detector in my car that shows volts and I've never had it go below 12.0 while flashing or using vagcom and I flash a new tune regularly. Don't use the windows or seat heaters thou
    Sent from my SM-G930V using Audizine mobile app
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    I've been messing with my car in the "on" position for maybe 3 hours and didn't have any issues. Audi is just covering their ass with that statement. But if you think the sky might fall, any basic battery tender/jumper would be fine. This really isn't a big deal.
    2013 S4 - 200mm crank pulley (3.162 ratio), 034 Stage 2+, USP intake, MercRacing HX, Sachs XTend clutch, SS clutch line, Borla exhaust, gutted cats
    Veteran Member Three Rings BozMan-S4's Avatar
    Jan 15 2018
    Cadillac STS- V Series
    Michigan
    Just a consideration...
    hooked up the battery charger and didn’t need too > no harm done and 2 mins investment
    Don’t hook up battery charger and car dies > F’s something up...hundreds/thousands at a dealership
    **Hours of research to learn the process, invest the 2 minutes. Not bashing or anything just sharing a thought. This will guarantee you will never be the guy/girl that wished they did...no one wrights a suggestion because they had extra ink and paper lol
    2011 Audi S4 Meteor Gray Pearl, Alu Kreuz, Eurocode Sways/Endlinks/Inserts, ECS Carbon Fiber Intake, 57mm Pulley, EPL Stg 2 ECU/TCU, AMS Alpha Cooler, ECS Street/Trans Shield, ECS Control Arm Brace, Milltek Non-Res Black Oval
    Established Member Two Rings SVG's Avatar
    Jul 05 2016
    68’ Ca Spcl, 96’ CTD, 05’ LJ Rubicon (sold), 06’ Victory JP, 14’ S4, 17’ Rav4 Hybrid
    Ca/MT
    I hook up a charger when doing the rear brakes. I haven’t used a charger for coding or flashing.
    Like Boz says, for a 2 minute effort it seems the prudent thing to do.
    2014 Estoril Blue S4
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    I concur with connecting a battery charger when working with the Electronic Parking Brake (EPB) calipers on the rear. Mentioned in the Ross-Tech parking brake repair steps here, and explicitly referenced in the accompanying video:
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 21 2017
    I agree, prudent to use a charger. Some of these chargers like to put out pulses of higher voltages, not sure that’s ideal while coding though?
    Sent from my iPad using Tapatalk Pro
    BMW M850i
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    I think if your battery is unable to last 2 hours in the on position, even with the radio on, it's just a dead battery. I can't imagine going to a drive in and the car can't last an entire movie.
    2013 S4 6MT mods:
    APR intake backpipe w/ modded stock airbox, AFE Air Filter, CTS 187mm crank, APR 57mm charger, APR HX, Stasis Catback, CR-15, 034 Stage 2+/034 Stage 1 CARB
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    i did rear brakes on my A5 for the first time this past weekend.
    followed the referenced utube video by by LYKUNO to the 't'....
    added time to the process... 20 minutes (being V cautious since i was swapping out calipers, too)
    result.... no issues, none at all....
    why risk?
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
    Jul 05 2016
    Ontario
    If the battery dies while you’re recoding something, you’re going to have a very bad, and very very expensive day. Hook up a tender and guarantee success Or just roll the dice and hope you don’t brick your car.
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by jonwoods View Post
    I agree, a $40 battery charger is cheap insurance.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Where can you get a charger for 40 dollars? I bought a battery tended for that price but it's not the same thing. I asked in a different post if hooking up jumper cables will work, or if that would somehow over amp the ecu and no one gave me a answer. So here is the question. If I hook up jumper cables to a good car (wife's 2017 Q5) will it help? And second should I have her car running?
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Dec 03 2008
    2018 SQ5
    Quote Originally Posted by TexasDfwS4 View Post
    https://www.walmart.com/ip/Stanley-1...Start/38243759
    I use the $60 version of this one that charges at 25 amps though
