Results 1 to 22 of 22
    Mar 27 2018
    Chicago, IL
    B8.5 RS4 grill with license plate
    Hey guys, I've searched high and low for this information, but I'm looking for an Ebay RS style grill, all black but the emblem, that I can also put a US license plate on. Any links to proven ebay grills would be great! TIA
    Veteran Member Four Rings tar's Avatar
    Jul 07 2009
    B8 S4, Orange B5 Avant
    Socal/IE
    stone carbon is seller most use. comes with a bracket for europlate that im sure a us plate will fit on, never tried as the bracket was thrown away almost right away.
    2011 S4 6mt Black/ Magma/ Carbon
    HRE ff01 | Rotiform ind-t | AWE Touring | P3 | Roc Euro | PLM | Eurocode Sways | Apr Stage 2 | H&R Sport | Q5 ECS Wave F/R | CR15 | AK | Eurocode Inserts | 034 subframe Inserts | Ecs Carbon Diffuser | JHM CP | ECS Short Shifter |
    Apr 05 2016
    Portland, OR
    You will have to DIY a bracket or run a tow hook mount.
    I mount mine up like this:
    Mine is only ever on my car when I street park downtown though as I don't like parking tickets.
    Geoff
    Mar 27 2018
    Chicago, IL
    Do you remember where you got that grill from? I don't mind the DIY license part. Did you have to do anything to the crash bar behind it?
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by whiped View Post
    That's pretty damn clever!
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Mar 27 2018
    Chicago, IL
    I see this one, which has the smaller mesh behind the logo, like your...but has a bunch of holes in it which I'm not a fan of (I realize that two of them are for the euro plate):
    https://www.ebay.com/itm/Honeycomb-S...VaoOrI&vxp=mtr
    Then I also see this one, which doesn't have the holes in the mesh, but also doensn't have the smaller mesh behind the logo:
    https://www.ebay.com/itm/2013-2016-A...xaaRlS&vxp=mtr
    The last one also seems to have something that can cover the crash bar? I think that's what it's for if I'm not mistaken?
    Apr 05 2016
    Portland, OR
    I got mine long ago, I was looking for a specific style and it took a while to find.
    I don't think the seller has them anymore.
    I used black bed liner on the crash bar. It holds up way better than paint or plastidip.
    Geoff
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    @whiped
    Do you drive with it on or just slap it on when parked? I’d be interested to hear if it’s secure enough to drive around with.
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
    Senior Member Three Rings rvcahawaii808's Avatar
    Mar 18 2017
    Portland, OR
    Quote Originally Posted by BigBluu View Post
    @whiped
    i use this method. i forgot i put it on once and i drove for 40 minutes on the freeway. so id say it was pretty secure lol
    May 12 2015
    NorCal
    Pardon my ignorance/density on this one, but what exactly is that hardware you're using and how exactly is that mountable/unmountable to the grill?
    Jun 16 2018
    Denver, Colorado
    I just installed my RS4 mesh grille. A little upset that the Audi emblem holder and license plate brackets weren’t included, will submit a claim with Amazon.
    Have you considered the tow hook license plate holder? That’s the route I am going.
    https://www.amazon.com/Version-Bumpe...PML&ref=plSrch
    May 12 2015
    NorCal
    Yeah, I just really dislike that look. I'd sooner zip tie the plate to the front of the grille than run it offset and sticking out that far from the two hook area.
    Jul 02 2013
    Quote Originally Posted by FliGi7 View Post
    Honestly, as long as you don't mount the plate all the way down on the plain RS grille, it still looks fine, just leave some honeycomb showing under the plate. Unfortunately, the "Quattro" logo grilles are SOL, it's either nothing or tow hook.
    May 12 2015
    NorCal
    It seems @whiped has figured out a different solution, it appears. That's why I was curious on what hardware exactly he was using to achieve his setup and how it was done.
    Jul 02 2013
    Yes, his temporary toggle bolt set-up is nice and neat. I started down that road, but since I was putting the hex mesh right behind my grille, the big toggle bolts didn't work.
    May 12 2015
    NorCal
    Interesting. Two questions...
    1) Where did you get that hex mesh?
    2) What did you use to build that plate setup?
    Jul 02 2013
    The aluminum hex mesh is from McNichols, they give you enough to do two screens ( 36 by 24" ) so I bought the extra from another AZer, but you can get it here. https://www.mcnichols.com/perforated...um-al-17642732
    The plate holder was just a cheap plastic one from O'Reilly's ( $ 6 ) , and got all the hardware at Ace. I used the existing solid plastic hex that were in the grille that the Euro Plate would attach to, then bolted it behind the grille, and then through the screen, and used lock nuts to secure the screen itself.
    May 12 2015
    NorCal
    Great. Thanks for the link.
    Aug 15 2020
    Chicago
    @sacandagaD I love what you did with putting the hex mesh behind the grill. Any input on how you secured that mesh to the back of the RS grill?
    Jul 02 2013
    Quote Originally Posted by ChicagoDawg24 View Post
    Thanks! I actually trimmed the mesh so it was just slightly larger than the sides of the grille and pressed it in, and the two license plate bolts secure it from moving. It's been on for 2 1/2 years now, and it's still securely in place. One of these days, I actually need to take it back off, and respray the crash bumper since it has started to flake off.
    Aug 15 2020
    Chicago
    Thanks for the info! Going to try and order the mesh from the same place you got it from. Is the mesh silver or black in color? Still waiting for my grill but would like to get all the parts ordered. I've read that using trunk liner for the crash bar is a little better than just regular paint, so I might give that a go.
    Jul 02 2013
    Silver, so I painted the mesh with flat black spray paint, and the crash bar with bed liner.
