    Veteran Member Four Rings Dondbg's Avatar
    Mar 12 2016
    B6 S4 2005 manual swap
    The land of Kiwis
    How do you the chain is kaboom
    How do you know if the chain is Kaboom!
    Hey Guys.
    I bought a used S4 B6, I will try to fix it, if I see that it’s going to cost a lot then will part it and wait for another one.
    Now, the one I bought advertised as;
    Vehicle does not start. Vehicle has water in radiator and oil in engine. It is suspected that there is mechanical damage to this vehicle. Interior is in average condition. Two keys are available.
    With 214 k km, I guess the chain snapped.
    What would be the fastest way to tell if it’s the chain or something else ? Apart from removing the VCs
    Will a scan show me something ?
    Link to the car: https://www.turners.co.nz/Damaged-Ve...i/s4/15920789/
    Will be getting it by end of this week
    Mar 12 2016
    The land of Kiwis
    I got the car
    Scanned and got ton or errors from the engine controller mostly from camshaft positioning / sensor
    If I try to start the car, I can hear the starter spins free / loose.
    I guess it’s the chain.
    Anyone ?
    Mar 12 2016
    The land of Kiwis
    Yes engine is dead 🤷*♂️
    Address 01: Engine Labels: 079-910-560-BBK.lbl
    Part No SW: 8E0 910 560 F HW: 8E0 907 560
    Component: 4.2L V8/5V G 0020
    Coding: 0005771
    Shop #: WSC 63351 000 00000
    VCID: 2847EE0302F3EE7277F06E5-515E
    6 Faults Found:
    17755 - Camshaft Position Sensor 2 (G163) / Engine Speed Sensor (G28)
    P1347 - 001 - Incor. Correl. - Intermittent
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
    P1340 - 001 - Incor. Correlation - Intermittent
    16730 - Camshaft Position Sensor (G163)
    P0346 - 004 - Implausible Signal - Intermittent
    16725 - Camshaft Position Sensor (G40)
    P0341 - 004 - Implausible Signal
    18010 - Power Supply Terminal 30
    P1602 - 002 - Voltage too Low - Intermittent
    18308 - Coolant Fan Control 2
    P1900 - 004 - Open or Short to Ground - Intermittent
    Readiness: 0000 1000
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Are you playing a guessing game or do you intend to open the motor and inspect the actual issue?
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Mar 12 2016
    The land of Kiwis
    I’m going to open it.
    Those questions were before the car actually here.
    After I scanned it I realised it’s toast.
