Page 1 of 6 123 ... LastLast
Results 1 to 40 of 241
    Jan 01 2018
    utah
    Bb k24, meth and hopefully e85
    I have been gathering parts and whatnot for the last 4 months and have been without my car for the last 5. Long story short. I bought the car November of last year. Drove down to Phoenix to get it. Drove really great. Full awe stage 3 rods balanced and all the goodies that come with it. On Christmas eve I decided it would be a good idea to go do some donuts in the snow. Apparently this was the wrong time cause it was extremely slick out and I managed to slide right into a curb.
    Picture is kinda dark but you can see tha damage.
    Got some insurance money. A little not a lot and decided to just tear it down and make it faster than a normal k04 car.
    Service position. Sat like this for a week. Then engine and everything came out.
    Decide on bb k24s because of the Garrett name and rep. I don't want to have to do this again for a while. Got some 1000cc injectors and all the supporting mods.
    Got everything stripped down. And was waiting on everything for a minute. I did not want to start this rebuild unless I had everything.
    This is where I'm at now.
    Pretty irritated about this. I'm almost positive the outlet isn't at the right angle.
    Veteran Member Four Rings JustManson's Avatar
    Oct 11 2016
    Connecticut
    Looks like you have got a good amount of work into this build already. Sucks about the Curb incident.
    It looks to me atleast that maybe the turbo needs to be clocked a bit to center up to the piping.
    Jan 01 2018
    utah
    Quote Originally Posted by JustManson View Post
    If I clock it anymore the other way the coolant line gets in the way.
    Does anyone know what the s shaped hose goes to in the inlet kits? If it's not needed I can cut that and make the hose fit the way it is.
    Jul 04 2012
    Woodbridge, VA
    Quote Originally Posted by travis_w View Post
    s shaped hose is for lower PS IC
    Jan 01 2018
    utah
    Quote Originally Posted by vavJETTAw36 View Post
    But if I am already getting a new hose kit I shouldn't need it right?
    Jul 04 2012
    Woodbridge, VA
    if you are getting a hose kit from say 034, no, you will not need to buy it separate as the kit will have it.
    The kit has lower hoses and the boost hoses coming off the outlets for the turbos. Cant recall if it has anything else but a quick search would tell you.
    Veteran Member Three Rings uponone nogaro's Avatar
    Sep 13 2011
    01 Silver S4, 00 Noggy S4 Sport Package, B8.5 Dsg S4 Dual Pulley,240sx w/2j swap
    Bay Area CA.
    Nice I'm in the Same position with my BB turbos
    Senior Member Three Rings Teck09's Avatar
    May 11 2017
    WA
    I am not out in the garage at the moment but iirc it looks like you could trim the stock hose in order to get it to fit. Doesn't look too bad in the picture. Ideal? No, but def manageable. It can get frustrating though as these engines are already an extra 2lbs of shit too heavy for the bag they are suppose to fit in.
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    It looks like the hard pipe from the turbo to IC is wrapped, I don't recommend doing that, air exiting the turbo gets quite warm and cooling it is desirable.
    Jan 01 2018
    utah
    I agree. This is what came on the car and will be coming off.
    Jan 01 2018
    utah
    What do you think of the reflective tape shit. The gold stuff?
    Jul 04 2012
    Woodbridge, VA
    Bling factor only.
    Jan 01 2018
    utah
    Bling factor only.
    Cool. Don't want to buy it if I don't have to.
    Apr 07 2011
    Home of the mighty beaver
    get a 45 degree silicone elbow, its not ideal but it will work fine.
    Jan 01 2018
    utah
    Quote Originally Posted by S4James View Post
    My only issue is that the starter sits so close to it I don't knmow if it will work. I am going to try it when I get home tonight a d see what it looks like.
    May 11 2017
    WA
    Any chance you have the hard pipe bolted on upside down? Try flipping it over and see if that solves you problem.
    Jan 01 2018
    utah
    Quote Originally Posted by Teck09 View Post
    Can't put it on upside down. I am going to try the silicone hose that came in the kit and cut it down tonight and see how it sits. It's just one of those things of if it was a little more "correct" then it would be doable for sure. I'm going to mock up the starter and try it.
    May 11 2017
    WA
    You're prob right but I could have sworn that I initially put mine on upside down, hmm maybe it was the drivers side. Either way, hopefully you get it sorted. I like you have been without my car for a while, getting close to being back on the road but these little inconveniences similar to what you're dealing with keep popping up. Seems like a never ending process lol!
    Jan 01 2018
    utah
    It's almost impossible. The a.c. lines run underneath it. So putting it upside down is basically a no go
    Jan 01 2018
    utah
    If any of you are thinking about doing the tial option do it through srm. I did mine by my self and they were kinda a bitch.
    Jul 04 2012
    Woodbridge, VA
    Def not the correct angle. Here’s more or less what it should look like, though a bit off.
    Sep 13 2011
    Bay Area CA.
    The passenger side uses a 45 degree silicone hose,
    Jan 01 2018
    utah
    Thanks to uponone for sending me a 45. Much appreciated.
    Sep 13 2011
    Bay Area CA.
    No worries man will go out tomorrow
    Jan 01 2018
    utah
    I some how got a straight one to work. If the one upnone gets here I will install the 45 but until then this should work.
    The outlet sits really close to the starter. Contemplating installing a new starter cause this would be a bitch to change in the car.
    Jan 01 2018
    utah
    Trans installed. Jhm kit installed when it was rebuilt. If anyone in utah is looking to get any trans rebuilt I would highly recommend j&g transmission in salt lake. They do all the fleet trucks where I work and have been way more than excellent in customer service and quality of work.
    Fully mounted up. I think I'm going to try and do a boost test with it out of the car and see what happens. Has anyone done this?
    Jan 01 2018
    utah
    Downpipes wrapped. I got the tool to do the metal ties for the wrap and it doesn't work worth a shit. I ended up using a pair of pliers and a prybar.
    Jan 01 2018
    utah
    Haven't posted in a minute in this thread. What kind of oil are you guys running in your trans? I live in utah and deal with cold weather. Also just had the trans rebuilt. Any help would be appreciated
    Mar 22 2013
    AK
    Stock fluid is (Castrol) synthetic
    Apr 07 2011
    Run stock or run fuches titan sintomesh
    Jan 01 2018
    utah
    Cool.
    I cheaped out and bought that shitty ass autobahn hose kit and while most of the hoses fit I'm pretty sure the lobster claws won't. Does anyone know if the 034 big bore work well with the stock y pipe?
    Oct 11 2016
    Connecticut
    I use BlauParts oil for the Trans and Read Diff.
    https://www.blauparts.com/proddetail.asp?prod=J1C1001-A
    Apr 07 2011
    uh.. ravenol?
    how long will my trans work?
    quoth the ravenol..."Nevermore"
    - - - Updated - - -
    ok so i might have had a few glasses of wine.
    Jan 01 2018
    utah
    uh.. ravenol?
    - - - Updated - - -
    What the hell?
    Feb 23 2010
    Emmaus Pa
    uh.. ravenol?
    - - - Updated - - -
    Reference understood. And OP, Fuchs titan for me,
    Jan 01 2018
    utah
    So while installing my coil conversion I noticed that the adapter plate doesn't sit directly lined up with the hole.
    Jan 01 2018
    utah
    What's up with this? Is it supposed to be this way. 20180527_115820.jpeg20180527_115720.jpeg
    Jan 01 2018
    utah
    I ended up doing the adapters like in the second pic. The coils wouldn't go in the first way.
    Got injectors in. I thought they were plug and play but I guess I have to wire the new plugs on.
    Jan 01 2018
    utah
    Is it ok to just butt connect the injector harness or do I need to solder the wires. I know that solder can create some resistance and what not or just buy the adapters. These injectors look to be Bosch cores so I believe I would need the ev14 to ev1. I'm I correct on that?
    Jul 04 2012
    Woodbridge, VA
    For the coil adapter plates, the first pic is wrong, the second pic is the correct way. The spark plugs do not sit perfectly perpendicular relative to the valve cover.
    As for fuel injectors, I personally would run adapters. If you opt to chop up the factory harness, I personally would solder Not butt connect. That’s personal preference though. If not done properly, both solder and butt connector methods can create resistance.
    Here are the injector harness I run:
