Page 6 of 7 FirstFirst ... 4567 LastLast
Results 201 to 240 of 241
  1. #201
    Oct 27 2011
    TOYS
    Philly Suburbs
    raceware studs, arp, OEM will all be fine for your application. I am using OEM head bolts at 40-45psi BTW (my ARP studs were at the machine shop with my new engine that was getting built).
  2. #202
    Jan 01 2018
    utah
    Found another issue.
    Sent from my SM-S928U using Tapatalk
  3. #203
    Junior Member Two Rings
    Dec 01 2021
    Plymouth
    Ouch, that might be toast :(
  4. #204
    Jan 01 2018
    utah
    Yeah. I don't know how that happened when I have zero issues on my oil sample. Is what it is I guess.
    Sent from my SM-S928U using Audizine Forum mobile app
  5. #205
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Kinda looks like it was made from the metal spring inside of the cam seal. I’d pull another cap and that one looks good I’d clean the bad one up and send it.
  6. #206
    Jan 01 2018
    utah
    They all look good besides that end cap. I'm going to take apart the second head tomorrow, and hopefully, there aren't any other issues.
    The scarring also isn't where the seal rides. It's right on the "bearing."
    I wonder if something was done during the rebuild that could have contributed to both these failers. Obviously, there are 2 different issues that do not relate with one another but seem like installer errors.
    If I do go with some new heads, is there anything I should look into doing before I get them tested and resurfaced?
  7. #207
    Nov 13 2018
    Ocean city NJ
    I ment the spring popped out, moved to that area, and left the scoring.
    I forgot the heads were already off car. Knowing that I’d definitely pick another set up and have them gone through/resurfaced and toss them on.
  8. #208
    Jan 01 2018
    utah
    Thinking about purchasing the rs4 head in the classifieds. Would it be worth it? There are a couple hairline cracks in the dome which I have read are ok.
  9. #209
    Jan 01 2018
    utah
    Or 2.8 heads.
    I'm struggling with what to do moving forward. A lot of the threads are mixed on benefits on k24s.
    Right now, according to Brad, I'm at 530whp at 4400 elevation. I'm not really caring about hp numbers, but more about a good power band that's fun to drive in all aspects.
  10. #210
    May 10 2018
    MA
    2.8 cams is all you need
  11. #211
    Jan 01 2018
    utah
    I have to buy new heads anyway. The machine shop said one is not repairable and the other is damaged but can be used. I don't know if I like that.
    Is it worth doing springs and retainers? I feel like when I'm at 7k I can keep going.
  12. #212
    Nov 13 2018
    Ocean city NJ
    If powerband is what you care about I would steer away from 2.8 heads. I’d get another set of 2.7 heads and maybe some 2.8 intake cams but don’t expect much from them.
  13. #213
    Jan 01 2018
    utah
    What's your opinion on the azr heads if you have one?
  14. #214
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by travis_w View Post
    I have seen people complain about the AZR heads cracking at the spark plug threads on the euro forums. I am in the camp of just match the heads to the intake manifold you plan to run. So if running an RS4 IM - use 2.8 heads, if running an S4 IM - use stock 2.7 heads. People have made good power with both head types, and with stock cams we are all leaving a bunch of top end power on the table, but not much we can do since aftermarket cams were not popular on this platform. And to throw salt in the wound, people that tried aftermarket cams usually ended up with catastrophic engine failure - which is why I never bothered playing with cams other than 2.8 intake cams.
  15. #215
    Jan 01 2018
    utah
    I was going to reuse my stock intake manifold but port it to fit the azr heads but worried it still might be a bottle neck.
  16. #216
    May 10 2018
    MA
    Only way to know is to see things on a detailed log/dyno. How something feels is one thing, but the data will never lie.
  17. #217
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    On k24s, I was running 2.38-2.45 FATS consistently in summer temps. Stock throttle body, stock IM, stock Y pipe, the standard SRM inlets, stock heads with 2.8 cams. Just food for thought. If you’re going to spend money on anything, I would do valve springs.
  18. #218
    Jan 01 2018
    utah
    My last log was 2.83 fats on 2.7 everything. Maybe I'll just do the cam and springs.
    Would the azr heads help with spooling since the air velocity will be greater, or would it be negligible?
  19. #219
    Senior Member Two Rings eurogz's Avatar
    Apr 02 2021
    SE PA
    Bigger ports would decrease velocity not increase it. You would see in increase in volume at higher rpm, but would probably spool later not earlier.
  20. #220
    Jan 01 2018
    utah
    The exhaust ports on an azr head are smaller....
  21. #221
    Apr 02 2021
    SE PA
    Bb k24, meth and hopefully e85
    You’re right I thought they were bigger like 2.4 / 2.8 heads
    Real world difference is probably negligible
  22. #222
    Jan 01 2018
    utah
    Deep down, I kinda want to try it, but I can't bring myself to pull the trigger.
  23. #223
    Feb 23 2010
    Emmaus Pa
    You’re in the “it’s broke, keep upgrading parts” trap. I would just put the car back together, get it running right, and enjoy it.
  24. #224
    Jan 01 2018
    utah
    Damn. Man, you're right.
    On the lookout for some 2.7 heads.
    What years do I need to look for 2.8 cams? I read that anything older that 2000 won't work.
  25. #225
    Jan 01 2018
    utah
    Finally, I got some heads. I'm sending them to the machine shop tomorrow to get resurfaced
    How is everyone blocking off the sai ports. 034 doesn't make the plates anymore, I read about tapping the hole and putting a bolt in, but I don't really know about that.
  26. #226
    Oct 27 2011
    TOYS
    Philly Suburbs
    Just get some M6 screws, cut out a small piece of aluminum that fits the shape, mark and drill holes for the screws, apply some silicone sealant, tighten screws. Repeat for other head.
  27. #227
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    If you don't want to make them yourself, JAE still sells em and has gaskets. He's pretty quick.
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
  28. #228
    Jan 01 2018
    utah
    Just got word back from the machine shop. They are recommending I replace the cct because the pads are cracking. I told them I wanted to just do the pads, and he replied, "The tensioners usually fail, so we highly recommend replacing the cct." Heads have no warp, but he still suggested resurfacing the heads just to be safe and also have a little leak from a vac test, so they want to do a valve job.
    Sounds like they want to do a bunch of stuff that may not need to be done.
    Any opinions. I kinda just want to replace the pads and clean the surface, and throw them on.
  29. #229
    Jan 01 2018
    utah
    Are there any other options out there besides the Amazon and ebay pads. Has anyone used them?
  30. #230
    May 10 2018
    MA
    The tensioners don’t fail often at all - it’s a pretty simple device. They can get a bit sticky, but can also be cleaned. The pads wear. And crack. Lots of us have changed pads. With that said, the best way is of course change the whole thing, so you know it’s new.
    As for the rest, no one can say, no ones measured it/seen it. All certainly plausible though. None of which should cost anything astronomical at all (excluding replacing the solenoids completely, as the oem ones are $$$)
  31. #231
    Oct 27 2011
    TOYS
    Philly Suburbs
    On top of what RMode said, don't buy the cheaper non OE tensioners. They don't hold position very well like the Audi branded tensioners. Either throw pads on the ones you have (that's what I would do since the machine shop is wrong and other than the pads, they don't fail often) or buy new OE Audi ones which probably cost as much as your whole engine... Also, I would do the valve job while they are already at the machine shop.
  32. #232
    May 10 2018
    MA
    I’ve brought new ones in before - they are definitely expensive, but not entire engine expensive (high $800s each after duties are factored in)
  33. #233
    Jan 01 2018
    utah
    They are nla right? I've looked but can't find anything eom
  34. #234
    Jan 01 2018
    utah
    While I was in there, I needed to reseal my lower oil pan. I pulled the upper also.
    Noticed oil squirter hit piston and broke off. The skirt and cylinder both look good.
  35. #235
    Jan 01 2018
    utah
    I also saw this. Looks like a name and serial number.
  36. #236
    Jan 01 2018
    utah
    Also got the heads from the machine shop, and both upper tensioners pads have zero cracks. They also put on the invoice that my guides are loose but didn't mention it when I was on the phone with them. I took the heads to a different machine shop, and he gave them a quick look and disagreed with most of their assessment. He is going to check them over again for a second opinion. I'll get pics as soon as I have them.
    I do have the old pads from my other cct's that I can use if the lower pads are cracked. I'm going to clean out the ones on the heads and reuse.
  37. #237
    May 10 2018
    MA
    From Audi usa, I believe so. I’m able to bring them in from tradition,
  38. #238
    May 10 2018
    MA
    Just get new pads, it doesn’t pay to start swapping used ones around.
  39. #239
    Jan 01 2018
    utah
    Finished pressure washing the engine bay. Looks much better now.
    I acquired a parts car that I'm going to start tearing down in the next week or so. Right now, it's getting garage organized time.
  40. #240
    Jan 01 2018
    utah
    Engine is back together with a different set of heads, 2 8 intake cams, new valve seals, and I did lap the valves.
    Trying to decide if I want to keep the stock fuel rail or not. I really hate the look of it and want to clean up the engine some before I put this back in.
