Page 5 of 7 FirstFirst ... 34567 LastLast
Results 161 to 200 of 241
  1. #161
    May 10 2018
    MA
    Quote Originally Posted by travis_w View Post
    The car is running good at idle now. The only issue I have is when I start it. It runs rich 10afr for a couple minutes before it slowly climbs back up to 14afr.
    Any ideas?
    Sent from my SM-S908U using Audizine Forum mobile app
    Sounds like a tune issue or a lazy wideband
  2. #162
    Jan 01 2018
    utah
    Pretty sure my heads are lifting. Coolant spraying when I hit full boost. Pressure tested it and can't find a leak, but I'm losing pressure. Yay....
  3. #163
    Jan 01 2018
    utah
    So I'm leaking a very small amount of air out of the overflow when I'm pressure testing the system. Has anyone had this same issue? Tank cracked?
  4. #164
    Jan 01 2018
    utah
    Compression was good across all cylinders. 150ish with one reading 160.
    Going to get a tank and cap from the dealer tomorrow and hope that fixes it.
  5. #165
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Either the tank is cracked or the pressure tester isn’t sealed to the tank. I’m not sure if you can still get oem tanks from the dealer or not.
  6. #166
    Veteran Member Four Rings Silverex's Avatar
    Nov 13 2018
    Ocean city NJ
    Quote Originally Posted by CELison View Post
    Rmode should still be able to get em
  7. #167
    May 10 2018
    MA
    Quote Originally Posted by Silverex View Post
    I have 20 arriving later this month
    It's totally discontinued by Audi USA - has been for quite some time.
  8. #168
    Jan 01 2018
    utah
    Damn. She said they would have to order it and I could have it by tomorrow. Wonder if it's not oem.. I will post what I find out.
  9. #169
    May 10 2018
    MA
    If she is with Audi, she will find out, she can’t order it. It’s NLA for them in the US. I took every single one in North America last year, which was 4 lol. And then it became a popular item for me after I posted my brand new one in a picture on my car, so I began getting it from Tradition in bulk. Anywhere from 20-50 at a time. Same goes for the windshield washer reservoir.
    https://parts.audiusa.com/p/54290030/8D0121403M.html
    It’s why ECS, who simply gets Audi stuff from their local dealer, keeps pushing their arrivals out. It will never arrive is my guess. They’ve pushed out eta’s at least half a dozen times. Eventually it will be listed as discontinued.
  10. #170
    Jan 01 2018
    utah
    Unavailable. She said go aftermarket, which is what I did, and it seems like it's screwing me now. I was going to ask about ecs cause it shows theirs in stock, but it sounds like that's not the case.
  11. #171
    May 10 2018
    MA
    Bb k24, meth and hopefully e85
    It doesn’t show in their stock
    I’m the only one I’m aware of who’s had these in recent months. FCP had one left - Jesse got it, as I was awaiting a batch.
    I had a bunch of people who got multiple at once, which is partially why they leave so fast. Shipping them over also isn’t cheap, but I’ll keep doing it till I’ve exhausted their supply.
  12. #172
    Feb 23 2010
    Emmaus Pa
    I did get the last one. Which I just sold lol. I have another oem one if you need one to test. If you pay shipping you can have it. Cap too.
  13. #173
    Jan 01 2018
    utah
    Finally got my coolant res. After doing a couple pulls ot started spraying coolant and cutting boost at about 5500. Wierd thing is I don't thing the cap is sealing good. Tried to get one from the dealer and they we out of stock. So I bought a napa one.i attached a video of the cap. Looks like it's not sealing.
    https://youtube.com/shorts/DWGvqZyIW...U552e1e0Ffmont
    Sent from my SM-S928U using Audizine Forum mobile app
  14. #174
    Feb 23 2010
    Emmaus Pa
    The seal is on the O ring. Once it gets past that it’s going to blow out of the overflow and possibly where you see it. It sounds like your heads are lifting. I went through this same process hoping it wasn’t the case, but it was.
  15. #175
    Jan 01 2018
    utah
    Pulled a oil sample to confirm.
    I'm going to start my list.
    What head gaskets set should I go with. I'm obviously doing studs. Should I get the bottom end checked out?
  16. #176
    Jan 01 2018
    utah
    Have a weird thing happening. I left the pressure tester hooked up with pressure on it, it lost all pressure and my oil level raised and no more coolant in the res. So I accepted fate. Still waiting on the oil sample, I pulled the stick again last night and the level was back down to the same level as it was before the last pulls. So I gained oil level and then lost it again with no leaks on the ground. Any ideas?
  17. #177
    Jan 01 2018
    utah
    I cant figure out how to post the actual oil sample but this is what it says.
    Flagged data does not indicate an immediate need for maintenance action. Continue to observe the trend and monitor equipment and
    fluid conditions. LEAD is at a MODERATE LEVEL and may be OVERLAY METAL from MAIN/ROD BEARINGS; Viscosity is MODERATELY LOW.
    Causes include contamination, incorrectly identified viscosity grade, or adding a different viscosity grade to the component. Silver
    Possibly from solder; Please provide COMPONENT MANUFACTURER and MODEL to compare data to the correct standards for this
    component. Please provide missing FLUID PRODUCT NAME to compare data to the correct standards. Unit and/or lubricant TIME
    missing. Please provide this units sump capacity with next sample.
  18. #178
    Feb 23 2010
    Emmaus Pa
    Lifting heads typically doesn’t push coolant into the oil. It pushes combustion gases into the coolant system and the coolant out of the overflow.
  19. #179
    Jan 01 2018
    utah
    I know. My concern is im losing coolant somewhere and its not dripping. Also losing pressure
  20. #180
    Feb 23 2010
    Emmaus Pa
    It should be pretty easy to find if it's not getting into the oil. It doesn't make sense that it got into the oil then magically back out of the oil.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
  21. #181
    Jan 01 2018
    utah
    I find it weird. Ill tear into it this weekend and hopefully have some answers.
  22. #182
    Jan 01 2018
    utah
    I want to get head gaskets ordered. What's the best route to go? Elring?
  23. #183
    Nov 13 2018
    Ocean city NJ
    Erling is fine but I’d definitely get the heads resurfaced while they are off.
  24. #184
    Jan 01 2018
    utah
    I was going to have them gone through. Can't decide if I need to the block. I guess get it apart and see what the bottom end looks like.
  25. #185
    Jan 01 2018
    utah
    Any better options on the head gaskets. Are the tuners worth it at $250?
  26. #186
    Jan 01 2018
    utah
    Anyone have any luck with the Victor reinz gaskets? They any good? I use the brand at work but haven't used them on my car.
  27. #187
    Veteran Member Three Rings xRenesis's Avatar
    Jan 14 2015
    South Dakota
    I just did a reseal on my backup block I swapped into the car with victors, granted its been a week but nothings leaking at 22psi. Shouldn't have any issues with any that you go with tbh, being MLS.
    2005.5 A4 B7 - 2.7t K04 - DTM/S4 OEM+ (My B7 Rear BBK)
    2014 Q5 B8.5 - 3.0t (My B8/B8.5 Rear BBK)
    ig 1red_b7
  28. #188
    Jan 01 2018
    utah
    Just for shits and giggles, I threw on my old cap with the new resivor and pressure tested it. Very minimal loss of pressure at 15psi. Over 2 hours it dropped to 11 psi. I can hear it still leaking out of the overflow on the bottom of the tank. So I went out and drove it, and it did drip a little coolant onto the manifold but not nearly as much as before and no loss of power at 5500. Went all the way to 7k with zero issues.
    I'm going to order the oem cap and see what happens.
  29. #189
    Feb 23 2010
    Emmaus Pa
    If you’re loosing pressure out of the overflow with a pressure tester either the tester isn’t sealed or the tank is cracked.
  30. #190
    Jan 01 2018
    utah
    I didn't use a normal pressure tester this time. I made it so I had pressure going in the top port of the tank and left the cap on. I also tried it this way with the new napa cap, and it immediately lost all pressure through the cap. If im not mistaken, this should eliminate the tester not sealing correctly and test the cap at the same time.
  31. #191
    Jan 01 2018
    utah
    Still blowing coolant. Are oem headgaskets nla? Ordered head studs. Just need to order head gaskets and the associated seals.
    Any input???
  32. #192
    Feb 23 2010
    Emmaus Pa
    The aftermarket HGs work just fine
  33. #193
    Jan 01 2018
    utah
    Just removed the timing stuff. Question is, I just put this belt on less than 1500 miles ago and the water pump is a oem audi one put in 30k ago, do I reuse the belt and the water pump as there isn't any movement in the pump.
    The pulleys will get replaced. I do see some grease coming out of one of them, and the other feels a little loose. I will also be getting a new tensioner
  34. #194
    Nov 13 2018
    Ocean city NJ
    If you marked the rotation you could reuse it but they are cheap enough
    FWIW: Buy parts from FCP so when you’re in that kind of situation you can get a free replacement
  35. #195
    Jan 01 2018
    utah
    Have the heads taken off and found that the blick is already studded, but the nut on the stud is the regular audi head bit style. My arp studs are triple square. What kind of studs are these?
    I also did find a very small kind of crack, maybe. It's just on the surface of the head but doesn't protrude into the chamber. Maybe under boost it opens up, but it doesn't look like any cracked head I've seen. How often are cracked heads on these?
    I can't get pictures to upload.
  36. #196
  37. #197
    Feb 23 2010
    Emmaus Pa
    That’s a problem
  38. #198
    Jan 01 2018
    utah
    It is. I'm dropping the head off tomorrow so they can take a look at it. There are a few more marks like that on the surface but they look like indents and not cracks. I guess I'll see what the machine shop says.
  39. #199
    Oct 27 2011
    TOYS
    Philly Suburbs
    Was the head gasket blown out in that area? That defect look too perfect to be a crack. Almost looks like the head was dropped on a sharp edge or someone scratched it with a razor blade. Hard to tell from a picture at one angle though...
  40. #200
    Jan 01 2018
    utah
    The gasket has the same line on it, and it looks like it has a path to a coolant passage. I'll try to upload more pics.
    I was very gentle with it. My first thought was it happened when it was installed.
    I did find out these are raceware studs, though. Can't decide if it want reuse them or throw in the apr studs I just bought.
