Results 1 to 6 of 6
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Change ECU tune from 1 to another
    I currently have REVO and would change to APR, do I need to re-flash to stock 1st ? or I can just over write the current tune?
    - iKe -
    2011 S5
    2011 A4 Avant
    Established Member Two Rings B8Brit's Avatar
    Sep 27 2016
    NE Ohio
    Why are you changing??
    Feb 21 2007
    Houston, TX, USA
    Need to bring in my car for oil consumption, my dealer recommends to flash it to APR as REVO when we flash back to stock will be detected, based on their experience Audi is friendlier with APR tune than others.
    - iKe -
    2011 S5
    2011 A4 Avant
    Senior Member Three Rings Jezza's Avatar
    Dec 14 2016
    Tuscaloosa/Alabama/South East
    That's not going to matter. Save your money. They can detect the tune whether it's been flashed back or not. Audi of America has taken a hardline stance on not fixing anything that they absolutely do not have to. They implemented this policy as a money saving measure. It sucks, but they are going to deny your warranty claim based on the tune. A warranty is a contract, so you could sue them for breach. I don't know how that would go, or if it makes sense economically. I'm not an attorney. The dealership may cut you a deal, but your chances of getting this fixed for $0 is 0%. Maybe you could pick up a second ecu and have it flashed with the right vin number. I have no idea if that would work, or if it would make sense. TL:DR, Changing the tune, even having it removed, is not going to matter under the circumstances.
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    When I took my car in for service, I always flashed it back to stock (Audi's Software), NOT the "stock" map from a tuner. I had good luck with this, never being flagged TD1. I even had them run software updates for a few modules (steering rack was the main one, the update seemed to reduce the deadzone in the middle of the steering wheel) and even then the system didn't flag me TD1
    The time I did get flagged TD1, I took my car in with the tune loaded. All they were doing was recalibrating my steering wheel sensor. Mom and pop shop who claimed to have the newest alignment equipment for the newest vehicles threw my steering sensor out of whack and could not recalibrate it. I tried a few times with VDCS with no luck. I was forced to go to the dealer, who fixed it in 20minutes....
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Four Rings Perry01's Avatar
    Jan 22 2016
    Touareg V8 FSI 8V A3 - B8.5 Q5 - MKVI GTI
    Hawaii and Utah
    If the dealer has to replace something costly under warranty, under direction from AoA, they will do a “deep dive” and find out if you have ever been tuned to avoid an expensive repair. You will get flagged TD1
    CPMA / CTS K04-0064 / IE custom tune / Wagner FMIC / Custom ZF8 TCU tune
