Results 1 to 18 of 18
    Veteran Member Three Rings AudiNike12's Avatar
    Oct 10 2017
    Sweden
    Front passenger side footwell- and door lights not working
    When I open the door, they don't light up. What could be the problem? Is it the microswitch in the door latch that's faulty? Also, when I open the door it doesn't show that the door is open in the display
    Audi A6 Allroad 2.7T -04
    Audi A6 2.4 Sedan -04
    Audi A6 3.2 Sedan -05
    Audi TT 1.8T -99
    Jul 25 2016
    1995 Land Rover Discovery
    Missouri
    Probably the door microswitch. Vag-com cam confirm if you're seeing a signal from that door, but I'd lay money on the microswitch.
    Oct 10 2017
    Sweden
    Ok. Does it help to clean and spray the microswitch or do I need a new door latch? And where on the door latch is the microswitch located? If that's the problem
    In VCDS it says "door closed" when open
    Audi TT 1.8T -99
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by AudiNike12 View Post
    Everything you need here : https://www.audiworld.com/tech/elec96.shtml
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Senior Member Two Rings Alex JB's Avatar
    May 08 2014
    Leicestershire, UK
    Wd40 and working the latch can fix the door bounce issue (where closing the door it bounces open to the outer of the two latch positions).
    I have the same microswitch issue, unfortunately I was told that the door card needs removing and the whole lock unit out to get at the switch
    Oct 10 2017
    Sweden
    Ok. Do I have to remove the window frame to remove the latch or can it be done without doing that?
    Audi TT 1.8T -99
    Nov 19 2006
    Too much crap
    WA
    Per the tech writeup I linked above (post #4) it's supposed to be possible, but in my own experience, it's much easier to remove the window frame first ...
    Oct 10 2017
    Sweden
    Quote Originally Posted by 02 A6 2.7T View Post
    Ah, thanks for the link. Didn't see it :)
    Audi TT 1.8T -99
    Oct 10 2017
    Sweden
    Do you know if a door latch from a A6 1998 fits a 2004? It says it should but I wanna be sure.
    Audi TT 1.8T -99
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    if the part numbers match, you're good
    also, link for 2 videos showing dis-assembly and reassembly of the door panel for latch replacement
    http://forums.quattroworld.com/allro...s/230337.phtml
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Oct 10 2017
    Sweden
    Quote Originally Posted by PaperToast View Post
    Thanks for the link
    For example, this door latch has both the part # for my 2004(401837016) and an A6 1998(4B1837016G). In the list it says it fits both. According to ETKA, 4B1837016G is before the facelift and 401837016 is after.
    https://www.ebay.de/itm/Turschloss-S...8AAOSwNRdX3nu9
    Audi TT 1.8T -99
    Oct 10 2017
    Sweden
    Of course the microswitch didn't work on the door latch I bought from the scrap yard. So I had to do some altering. I cut the 2 pins on the switch so I could move the switch/button closer to the cam, then I put some glue on so it would stick. And now it works. It was the same fault on both door latches. The buttons were worn down from the cam
    Audi TT 1.8T -99
    Veteran Member Four Rings m_haiser's Avatar
    Apr 24 2011
    2012 A6 Prestige, 1998 Jeep Cherokee XJ
    Central Willamette Valley
    My jetta had a similar problem so I bought the cheapest eBay latch I could find just for the microswitch
    Sent from my Z917VL using Tapatalk
    It's to the point where all the problems just run together in a spider web of disappointment and mush.
    -CELison
    Nov 19 2006
    Too much crap
    WA
    And then there's these ... https://www.ebay.com/itm/OEM-Right-D....c100011.m1850
    Apr 24 2011
    genius
    Oct 10 2017
    Sweden
    They don't ship to Sweden. Also, we have to pay a $10 fee if we order from China in Sweden. So stupid. Can I get them from somewhere else?
    Audi TT 1.8T -99
    Apr 29 2009
    Quadzilla
    Longmont, CO
    here are the switches i got a few months ago https://www.ebay.com/itm/Left-Right-...72.m2749.l2649
    its the 'upgraded' switch and a US seller, maybe they ship overseas
    Rockin' the Rockies
    Oct 10 2017
    Sweden
    Only ships in the US. Guess I'll just have to pay the extra fee. Not the end of the world
    Audi TT 1.8T -99
