Results 1 to 7 of 7
    Sep 19 2014
    Newcastle
    APR 91 vs 93 tune?
    I'm running APR stage 2 tune and have tested the 91 file and 93 file whilst only running 93 octane fuel. Monitoring timing advance they both seem to max out at around 44btdc. The 93 file makes about 3psi more boost but the timing looks the same. Does anyone know if the 93 or 104 octane file advance timing even further? Makes me wonder if there's still quite a bit of headroom left on this tune to advance further safely. I expected the 93 file to push it further than the 91 does. Maybe it's all boost requests.
    Sent from my Pixel 2 XL using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Oct 02 2005
    The Moon
    44 degrees of timing??? That doesn't sound right on race fuel let alone 91.
    Sep 19 2014
    Newcastle
    Quote Originally Posted by p3u View Post
    Really? Maybe I'm reading it wrong. It's just from torque pro so maybe it's measuring it incorrectly.
    Oct 02 2005
    The Moon
    Quote Originally Posted by pez81 View Post
    That might be why. Torque is useful for some things, but useless on others. I think this might be the later for timing lol. Do you have a VAG Com you could use to measure?
    Sep 19 2014
    Newcastle
    No but I'm thinking I should penny up for the cable already. Thanks
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Something is off -you’ll maybe see 15-17 on pump under perfect conditions and possibly low 20’s on 104
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Sep 19 2014
    Newcastle
    Quote Originally Posted by cobrario View Post
    AHH that makes more sense..plus no matter the tune I've had on the car or fuel used it's always showing the same. #torqueprofail
