    Nov 30 2016
    Audi R8 V10, Audi SQ7
    Norway
    Slightly overfilled oil on B7 RS4
    Hey! This is a silly question, but just to be safe I'll go ahead and ask anyway; When topping up my B7 RS4 with oil I seem to have slightly overfilled it. It's not reached the metal on the dipstick yet, but its covering the "MAX" on the plastic. Is this "fine", or should I drain some of it out asap?
    Jun 15 2017
    Wisconsin
    Yep, I did this too....major idiot moment. My understanding is that from the bottom of the hatches to the top is about 1l, depending on the oil temp. It’s been a while since I looked but over on RS246, the theory is that overfilling can not only cause the oil to run hotter than normal but also over pressurize the system causing leaks and/or failures.
    From your pic it looks like you’ve got 1.5-2 lts over. You’ve got two choices; drain and refill or use a syringe and a length of tubing to suck some out.
    Oct 12 2008
    NW Washington
    I would try to get it out asap.
    Get one of those hand pump vacuums and suck it out when the oil's warm, saves having to deal with the belly pan.
    Registered User Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Indeed, get some out before you start the engine! In addition to the above, oil may get in the cats (if you’ve still got them :-)), plug them and worse things may happens.
    Veteran Member Four Rings Axel-'s Avatar
    Jan 29 2011
    2006 JHM Stg 1 SC'd S4 Avant 6MT
    Toronto, CA
    Didn't you see the "Nicht Uberfullen!". Anyway, as the others have said, remove the excess before starting.
    Sprint Blue B7 S4 Avant 6MT - 421whp/350wtq - Review of all my mods
    JHM Stage 1 SC - JHM IM - JHM 5R clutch - JHM LWFW - Stoptech ST-60 BBK - KW v3 Coilovers - JHM shifter - Trexturk DP - Magnaflow CB - Hotchkis RSB - JHM IS - 034 Adj. FUCA - STE Gauges
