Units of lambda and O2 sensor voltage entirely different. An O2 sensor will not exceed 0.9v and never go below 0.1v. The sensor will always read in between these values, outside this boarder will indicate a circuit error and flag either the sensor or entire circuit as faulty.
Units of lambda is what I see monitored, that will just give you the AFR ratio if used 14.7 as stoichiometric.
To know if your running lean or rich by fuel trims, you take LT + ST. So if you have a LTFT +28% and a STFT if -23%, you would have a +5% value, meaning adding fuel. I doubt you would see a -23% in real life in STFT with +28% LTFT but I’m using those values as an example only.
Regardless, anything over +/-25% will trigger the MIL light, so in theory your light should be on flagging an issue. On average you shouldn’t see the LTFT more than %5 and generally anything near zero is preferred. As the engine ages I’ve seen values near 10% but usually start flagging issues with stuck rich/lean on upstream sensors.
So by looking at your LTFT and if you monitored the O2 voltage, you would see the car running lean, meaning the sensor voltage will average below 0.45v. It will most likely reach 0.19v and not breach past 0.69v. You can’t view this by looking at numbers, best is by using a scope or viewing live data as a graph when logging pids. Just don’t monitor stuff like rpm which uses a lot of data and solo out the O2 sensors.
To diagnose, shoot for things that bring in air or stuff that monitor air. The car has a MAF sensor so might be wise to start there first, especially if you have an oiled filter. If nothing is found, start looking at fuel pressures . Your getting to much unmetered air(hole in intake tube after MAF) OR not enough fuel(low fuel pressure) and limits are being exceeded to try and meet a mixture of 14.7:1
Sent from my iPhone using
Audizine
