Results 1 to 17 of 17
    Jan 17 2018
    San Tan Valley, AZ
    Assistance needed please - 2005 B6 S4 - Car Sputtering and shaking on startup
    Hi all,
    I recently got my engine back together from doing timing chains/guides on my 2005 B6 S4. Now that I have everything back together and back in the car, I tried starting the car today. I did crank the engine first with out the fuel fuse in. So after cranking first a few times, I put the fuel fuse in and the car fired up and seemed to run good. as it was running the coolant alert came up, so I shut the car down, and filled up the coolant again. I then went to start the car again, and it would catch but die right away. After a few tries the car will start and run, but will sputter and shake, then eventually die again.
    Everything seems fine with the fluids so far. But I am wondering if maybe I didn't do something right with the clutch.
    If I didn't do the clutch correctly, could it cause this type of issue? has anyone run into this before?
    Thanks in advance for your help!
    2005 Audi B6 S4 - Brilliant Red with Black Recaros and 6MT.
    RS4 Guides, chains, tensioners, JHM Cam Adjusters, JHM intake spacers, JHM 6 rib lightweight pulley kit, SPEC single mass flywheel, new stock clutch, new clutch slave cylinder, JHM 255 LPH fuel pump, etc......
    Veteran Member Three Rings jakeoboy67's Avatar
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    how long did it run for ?
    first thing I'm thinking about is air in the fuel system.
    Is your fuel rail returnless or with a return line ?
    the sputtering/shaking is simply due to a couple cylinders not firing.
    Jan 17 2018
    San Tan Valley, AZ
    Quote Originally Posted by jakeoboy67 View Post
    It ran for maybe 5 minutes the first time and sounded really good.
    The fuel rail is stock as far as I know. I did have it off due to the intake coming off for the timing job though.
    Oct 21 2013
    mk2 Jetta Tdi
    NB , Canada
    Quote Originally Posted by nschultz View Post
    if it ran good for 5 mins, then it should have cleared any air in the fuel rail.
    at this point I don't know why it would sputter/miss and die, Do you have any way of checking for codes ?
    Jan 17 2018
    San Tan Valley, AZ
    I have a Bluetooth obdII and torque, but It's not throwing any Cell's currently.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    maf plugged in?
    tb tight/adapted?
    do you have gas
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Jan 17 2018
    San Tan Valley, AZ
    Quote Originally Posted by badger. View Post
    maf plugged in?
    tb tight/adapted?
    do you have gas
    Yes, yes and yes....
    I'm trying to find someone with a vag-com cable in my area that can maybe help me out...
    Nov 12 2015
    Oregon
    Without having any scanner info to go off of it makes it hard. Definitely check your cam/crank sensor wiring and make 100% sure they are plugged in correctly. Other than that, check all vacuum lines to make sure they are all connected.
    Sent from my SM-N920V using Tapatalk
    My build log
    Registered User Two Rings
    Apr 03 2018
    Los Angeles, CA, USA
    Indeed best is to scan the code with VCDS/ODIS/similar and post it here.
    Jan 17 2018
    San Tan Valley, AZ
    I ordered a cable. Hopefully will have it in a few days. Thanks all!
    Jan 17 2018
    San Tan Valley, AZ
    My cable came and showed no issue other than the ABS module being out. I decided to get it back onto the stands, and took the starter out of it. The starter and battery both tested good. This was this past Sunday.
    After work today I put the front into service position and removed the plugs and coils. Since my pulleys and belt are new, I removed the main pulley, and put two bolts back in so I could turn the motor. When I did this, I had coolant come out of the passenger side #3 plug hole, the second time around it came out of the passenger side #2.
    At this point i don't think I really have any other option but to pull the motor again, and see if I can figure out where the coolant is coming from, and check the timing on it.
    I could also put the starter back in and crank it without any plugs in it, and see if I can get the coolant out.
    Any thoughts?
    Apr 03 2018
    Wow coolant coming out from the spark plugs holes is never good my man, that’s either head gasket, cracked head/block.
    Actually it may be a good idea to do a leak down test before you do anything further as this can pinpoint the problem better, even though the most likely outcome is that you’ll see the air leaking out from the coolant tank.
    Nov 12 2015
    Oregon
    Any thoughts?
    Coolant in wrong places is never good. I'd be careful cranking it with spark plugs In as water doesn't compress. I think cranking with plugs out would be a good start, or as mentioned, a leakdown test to see if you can pinpoint the issue.
    My build log
    Jan 17 2018
    San Tan Valley, AZ
    Quote Originally Posted by Grigor@Bestiale View Post
    Everything was good as far as I know when I took it apart, was just the broken guides. I did not take off the heads when I had it apart.
    Quote Originally Posted by VinnysS4 View Post
    Yeah the plugs are currently out. I'm wondering if something didn't seal up properly when I put everything back together.
    Junior Member Two Rings
    Sep 05 2014
    Delaware
    did you maybe mix up the coolant and PCV lines on/near the throttle body?
    Established Member Two Rings Mike50design's Avatar
    Feb 17 2017
    Mission/BC/Canada
    Quote Originally Posted by JQADDINGMACHINE View Post
    I'd always wondered if it was possible to get those lines mixed up.
    2007 Audi S4 (DTM)
    Nov 12 2015
    Oregon
    Quote Originally Posted by Mike50design View Post
    Somebody posted on here recently that he had done that and that. If I remember correctly when he took it to the shop he had a couple bent rods from hydrolocking the motor. Water doesn't compress like air LOL
    My build log
